forge DV question
06-13-2011, 03:24 AM | #1 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
forge DV question
Hello members;
I recently received my forge DV kit, I automatically switched the stock blue springs to the yellow ones. The kit included 6 washers apart. my question is, do I really need to use the washers that comes apart? or just install the yellow spring and that's it? Thanks. PS: I'm boosting 15 - 16 psi.
06-13-2011, 03:50 AM | #3 | |
184
Rep 2,320
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-13-2011, 03:55 AM | #4 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
yeah, but could this do any difference?
06-13-2011, 03:57 AM | #6 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
yeah, that's what I thought, tell **335i** lol
06-13-2011, 04:43 AM | #8 |
58
Rep 1,230
The washers/shims/spacers are obviously included so you can fine tune the DV's tension/pressure setting between any two springs provided. I think the concept of using the shims with the springs can be a very grey area.
The springs strongest to weakest are: Red - Blue - Yellow - Green - Black. Any car subjected to increasing boost pressure using a tune; should datalog the boost curve to see if you are hitting the tuners boost targets smoothly or if you have erratic and fluctuating boost. If the valve is dumping or losing boost pressure before hitting it's target, you need to re-tune the valve’s performance characteristic by changing to a stiffer spring. If the stiffer spring is holding on to boost for too long or it fails to release pressure beyond its' expected boost target, you should try inserting the spacers to the weaker spring first.........to see if it resolves the boost target issues. Note: Forge recommends the maximum use of only 2 spacers with any configuration.
Sticky is an Idiot
06-13-2011, 04:59 AM | #9 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
Beside that, what is your current setup?
06-13-2011, 05:57 AM | #10 |
184
Rep 2,320
i run now 14-15 psi so i think yellow springs should be used
06-13-2011, 05:31 PM | #11 | |
88
Rep 1,404
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
