Any E85 progress?
06-12-2011, 09:58 PM | #1 |
19
Rep 569
Any E85 progress?
I have searched and the prob is, the search doesn't recognize 3 letter words!!! ARGHH!!!
I have e85 less than 1.5 miles from my house. I have DCI, JB4, catless 3in DPs and soon to delete secondary cats. My buddy wants to line up some of his cars to see what mine will do. It'd be fun to run every once in a while in a small mix. |
06-12-2011, 10:24 PM | #2 | |
#Hashtag
Rep 245
Give it a shot and log. |
06-12-2011, 10:36 PM | #3 |
124
Rep 1,362
The thing about making big power with E85 is that you would need more fuel flow than stock. Because although E85 has a higher octane level than gasoline, it has a lower energy content. That is why most of the STi's, Evo's, and other FI cars run upgraded fuel pumps and injectors when converting to E85. The thing with the N54 is we dont have aftermarket injector's so we are limited in running E85, not to mention if our fuel system as a whole can handle it.
You can more than likely run up to a 50/50 mix with good results, but I wouldn't run it often. If I were you and wanted to run more boost against friends, I'd get race gas and call it a day. |
06-13-2011, 02:09 AM | #4 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
E85 mix
I always run 4 gal of E85 to a tank of Shell 91 and it runs great with more power. The Jb4 has been auto tuning to between 14.5-15.5 psi on it with your same mods.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
06-15-2011, 02:35 AM | #5 |
Rep 22
ok, this post comes from somebody not too familiar with N54 tuning options, but very familiar with EJ257 tuning (STI). For one, E-85 is corrosive to rubber, but you probably know that. Second, what's the point of dropping in E-85 and raising your octane level, but not adjust timing? What real advantage are you getting? Sounds like the risk isn't worth the reward. The benefit to e-85 is running more advance timing, and tons of it! it takes a retard to let it pre-detonate. From what I read, you guys run off the shelf maps for the most part. So what's the point of running E-85 if you can't adjust your map? Sorry...just reading about these cars cause I'm interested in getting a 335.
06-15-2011, 02:43 AM | #6 | |
161
Rep 7,377
with the e85 you can run 1-2 psi more probably with great results without any drops as you can do with meth injection.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-15-2011, 02:47 AM | #7 |
Rep 22
I'd have to see the timing map to see what's aggressive. Timing makes power, boost doesn't. So you increase boost but it pulls a few degrees of timing...could just cancel it's self out. Sounds like the risk is greater than the reward. So basically everybody relys with off the shelf maps from tuners, and runs E-85 and meth? Tell me that's not right!
06-15-2011, 02:55 AM | #8 |
Rep 22
I also wanted to throw it out there...since I didn't see it any where else, and the OP is obviously seeking info about E-85. E-85 doesn't read stoich AFR's. So to those who are logging their cars, what exactly are you looking for? My guess is your logs look at something like this. Boost, AFR, IAT, ignition timing, WGDC, Fuel tables, knock correction, right? So what exactly are you looking at? I'm just worried that you guys are doing damage to these beautiful, and expensive cars. Having experience in the import world, E-85 has been used in these cars for a while now, so we have quite a bit of useful information. Just don't want to read a thread about somebody popping their motor...my guess is it's quite expensive! Just food for thought for the OP.
06-15-2011, 03:20 AM | #9 |
247
Rep 1,827
I miss my E85 powered Evo9. The minute somebody figures out the fuel system to run E85 on the n54, I would not hesitate to run it again even if I get shitty gas mileage (11-15mpg depending how much fun I have).
06-15-2011, 07:34 AM | #10 |
General of the Armies
156
Rep 656
My buddy just got 98 miles from a full tank of e85 on his Evo X MR Touring. With a 13.7gal tank that is 7.15mpg on 385. This *is* pushing 450hp though.
06-15-2011, 08:50 AM | #11 | |
247
Rep 1,827
I personally would not try to make that kind of torque on those SST transmissions though. Props to him though. |
06-15-2011, 09:25 AM | #13 |
247
Rep 1,827
06-15-2011, 10:31 AM | #14 |
23
Rep 303
08-16-2011, 04:39 PM | #16 |
19
Rep 151
The general concensous seems to be that blends of up to 50/50 E85/gas are ok to use once and a while, but straight E85 will cause damage: http://www.n54tech.com/forums/showthread.php?t=11542
08-17-2011, 07:20 AM | #17 |
35
Rep 450
Another is that if ur hpfp craps out while running mixed 91/e85 or better than you MAY not get it covered since part if bmw's protocol is to test ethanol level in the fuel when it goes bad and if it has over a certain amount u may not get covered
