N54 big twins
06-11-2011, 02:43 PM | #1 |
86
Rep 1,262
N54 big twins
Has anyone attempted to fit bigger twins to the N54 rather than the reworked stock housings? Is space an issue in our engine bay?
I'm talking about something like a Garrett GT22 or GT25 sized housing. I feel it might be the perfect middle between the tiny TD03 housings and the mythical big single setups. thoughts?
Josh-
06-11-2011, 04:11 PM | #3 |
161
Rep 3,736
I'm wondering the same thing, is it the space cause I would rather purchase bigger twins than rework the stock housings..
06-11-2011, 04:13 PM | #4 | |
28
Rep 553
[SIZE="2"]335 E92 Space Gray/Coral/Aluminum/6MT
06-11-2011, 04:30 PM | #5 |
86
Rep 1,262
more like a mcdouble lol
Josh-
06-11-2011, 04:33 PM | #6 |
Got Boost?
Rep 234
not even the size of a big mac...TD03 is a little turbo...most bikes run larger when they go turbo...but it does give us instant spool.
I to would be more interested in a larger twin setup to retain some quick spool characteristic. Possible even going to a sequential setup. I like our low and midrange.
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport JB4|BMS DCI|MS 3" cattless DPs|Golf Tee|33% Tint|///M Pedals |
06-11-2011, 04:42 PM | #7 | |
28
Rep 553
06-11-2011, 05:54 PM | #8 |
52
Rep 529
thats the turbo i run on my sr20det powered altima, great turbo, fast spool.
RIP E46 M3
RIP E92 335i RIP F80 M3 Hello G80 M3 |
06-11-2011, 08:01 PM | #10 | |
86
Rep 1,262
The It'll be like managing a twin sequential setup (if that makes any sense whatsoever lol )
Josh-
06-11-2011, 08:53 PM | #11 |
142
Rep 2,661
ASR engineering turbos are char upgrades(garrett chars i think)
06-11-2011, 08:57 PM | #12 | |
Rep 101
No, it wouldnt. Twin scroll setups are controlled no different than single scroll would be. |
06-12-2011, 03:21 AM | #13 |
40
Rep 957
someone needs to pull the trigger on this. i think AR design should approach a larger twin turbo upgrade. i know theyre working on the single turbo but id like to see this as well.... somebody.
07 335i- SOLD, and will be missed...
Parts for sale- PWM meth kit, M steering wheel, M shift knob, perforated e brake handle |
06-12-2011, 03:34 AM | #14 |
494
Rep 1,922
Drives: 2021 G80 M3
well, sounds like ESS is comming out with a kit for N54. but yeah, space is a big problem.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
06-12-2011, 09:07 AM | #15 |
Rep 57
I have what I think is a stupid question but I'll ask anyway.
Is it possible to have 1 smaller turbo for lower RPM spool and a larger for high RPM spool? Best of both worlds but I'd imagine the ECU would have a tough time managing the different boost levels. |
06-12-2011, 09:58 AM | #16 |
86
Rep 1,262
It's not a stupid question at all! It does exist and is in fact quite common. In fact the N57 (335d engine) uses a setup like that. I'd say it is definitely possible, the hardest part would be to make sure the engine knows to not open both wastegates simultaneously?
Josh-
06-12-2011, 10:11 AM | #17 |
Rep 57
joshuo: iirc there were shops that attempted to go for the bigger twin set up, however space was the constraint. there is very little room to work with down there.. but hey maybe with enough time and money it may be possible!
06-12-2011, 10:23 AM | #18 | |
Rep 57
I know from my Suby days there was always a trade off with a single larger turbo but I love the idea of staggered turbos to cover the entire RPM range. Along time ago on the Suby board there was talk of a turbo/supercharger (single unit) that was supposed to be belt driven for low-end and exhaust driven with a clutch for high-end. Great idea and not sure why it's not used. I've definitely seen this done with two separate units. |
06-12-2011, 10:57 AM | #19 | |
70
Rep 2,197
06-12-2011, 11:03 AM | #20 |
3441
Rep 79,211
It can be done, but somebody needs to make a new exhaust manifold.
Aside from that connecting back to the hot side of the intercooler and use of oil and coolant lines is another thing. (if they are even used at all). The real dilemma is fuel, as we can't support over 450WHP without methanol as a fuel band-aid. Which brings you to the next upgrade needed which is likely secondary port fuel injection. After that you will likely want an LSD to put the power down and upgraded axles so add that to the list |
06-12-2011, 11:25 AM | #21 | |
86
Rep 1,262
Maybe if the manifolds were to be designed as to bring the turbos down lower, there would be more space (since the engine is canted to the passenger side).
Josh-
06-12-2011, 11:40 AM | #22 |
Got Boost?
Rep 234
That is what I was thinking...one in place of the current two area and the second sitting lower where the stock primary cats are.
