Meth nozzle size selection guide!
06-10-2011, 06:51 PM | #1 |
273
Rep 5,876
Finally a guide showing nozzle sizes as they relate to boost/psi and hp...
http://www.suprasport.com/Nozzle--Me...on_p_5540.html I'll be going down to an m10 from my current m14...always felt like it was overkill and it does bog sometimes.. |
06-10-2011, 07:09 PM | #2 |
161
Rep 7,377
Nice find so your m14 flows around 1000 ml/min which translates to 20 on procede flow.
Cant you regulate it ? You can just lower pump pressure or make it go full on higher psi. You prefer it smaller for atomization?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-10-2011, 07:16 PM | #3 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
Nice find!!
06-10-2011, 08:01 PM | #5 |
Joint Chiefs of Staff
4918
Rep 115,980
A generic M14 nozzle is normally 14 GPH or 14 * 3.78 LPH. Or around 882ml/min. I know the CM10 does around 750ml/min @ 180-200psi. For higher power applications many users have found they need anywhere from 1000-1800ml/min to hold full timing and a good air/fuel ratio. I don't think that chart works for the N54.
Mike |
06-10-2011, 08:10 PM | #6 |
307
Rep 5,175
Remember that is for 50/50 mixture and I suspect the reason they suggest these nozzle sizes is because of quench. A better way to choose your nozzle is determine how much water you want to spray, then use meth ratio to determine what nozzle is best for you needs.
06-10-2011, 09:35 PM | #7 |
177
Rep 6,631
CM10 + solenoid + 250psi pump with 90/10 or 100% meth with 18.5-19psi on stock turbos = no problems.
According to the Procede and JB4 meth output, that's around 950-1000 ml/min. Plenty for this application.
E90 LCI N54 6AT
06-10-2011, 10:03 PM | #8 |
158
Rep 1,288
Drives: 2014 435iX, FBO
What will the new PWM Meth kit come with... CM10s? Does anybody know?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
06-10-2011, 10:20 PM | #9 |
133
Rep 4,764
Two 1mm nozzles that are each close to M7's.
06-11-2011, 11:36 AM | #10 |
34
Rep 502
+1. This is the method decribed on the Howerton Engineering website.
Here is the link for those interested... http://howertonengineering.com/tech-...ating-jetting/ Describes in more detail. |
06-11-2011, 01:19 PM | #11 |
57
Rep 1,054
I've measured my flow several times and I'm always getting 900 ml/min with my CM10.
I have a relay who is feeding the pump directly from the battery instead of letting the boost switch doing this job. This results in 100% good voltage which the boost switch doesn't manage to deliver due to the nasty voltage drop that will occur with this solution. 100% good voltage to the pump means 100% good flow. I assume there's a risk of getting the same voltage drop using a CMGS or VC2... |
06-11-2011, 01:22 PM | #12 |
3441
Rep 79,211
PWM meth kit from vishnu is not comparable they use entirely different nozzles. However if I recall their dual nozzle setup is = to two m7 (but dont quote me) its somewhere in one of those threads.
06-11-2011, 02:19 PM | #13 | |
68
Rep 1,432
06-11-2011, 02:45 PM | #14 |
57
Rep 1,054
06-11-2011, 03:12 PM | #15 |
441
Rep 18,331
Its actually very smart to run the meth pump on a relay! I might one day even do this myself! Do a search on how relays work and how to wire it in...Its pretty simple once you understand how it works...I wired a relay to my automatic bottle opener for my nitrous even though the kit did not come with one...Works wonders on drawing current from the battery source rather than using a fuse-tap
