PWR radiator
06-10-2011, 02:19 PM | #1 |
161
Rep 7,377
PWR radiator
I finally now ordered the PWR radiator for my car. PWR is a well know company specialised in performance radiators from Australia.
I am getting tired seeing temp up to 111 C in traffic and around 106c at the track . My AT is probably the main cause and i am sure both the engine and AT will be much happier. I will log pre and after temps trying to simulate the same conditions. Price is 1100 usd shipped to their distributor in sweden. Will keep yo guys posted on the results and fitment! Will also check with them if they have an AT cooler.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
06-10-2011, 02:37 PM | #2 |
153
Rep 3,730
Pics when you get it? I'm going more towards the cooling route now since I'm maxed out with performance mods. AT cooler would be kickass!
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
06-10-2011, 02:47 PM | #4 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Nice. I would be interested to see your results as well. If the PWR radiator is able to keep the coolant temps down then the rest of us should be good as well. One thing I'd be worried is the LHD vs RHD engine bays.... I hope this won't matter but you never know.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
06-10-2011, 02:58 PM | #5 | |
161
Rep 7,377
06-10-2011, 03:44 PM | #7 |
184
Rep 2,320
i think this radiator applies more to AT for MT not necesary
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
06-10-2011, 04:23 PM | #10 | |
184
Rep 2,841
Your water pump must be working overtime! |
06-10-2011, 11:57 PM | #11 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
Nice enrita, keep us updated please.
06-11-2011, 12:28 AM | #12 |
81
Rep 1,510
very nice!
We're collecting water and oil data points over at the track forum, curious to see what improvements you'll see at the track with this radiator. Keep us posted and good luck!! |
06-11-2011, 09:32 AM | #14 |
292
Rep 2,898
Ilma -
Interesting information about the coolant temperature that triggers "component protection" mode (117 C/179 F). BMW motors in track cars are run at or below this temp for max efficiency, but I mistakenly imagined that the twin turbo N54 (at least with stock downpipes and cats) could be designed to run as efficiently at its higher operating temperatures. I was a liberal arts major (a long time ago), and my understanding of basic combustion engineering may be a bit underdeveloped... Neil |
06-11-2011, 09:38 AM | #15 | |
161
Rep 7,377
did you get a drawing to check if it fitted? mine had code 5970 Description: 2005 BMW 335i Twin Turbo 42mm Radiator Apparently. I know MT OEM radiator has a different code than the AT probably because the outlet for the gearbox heat exchanger.
06-11-2011, 09:38 AM | #16 | |
184
Rep 2,841
BTW.....I think 117C equates to over 200F since 100C = 212F. I guess art majors aren't so good at math either! j/k |
06-11-2011, 01:40 PM | #18 | |
36
Rep 1,329
06-20-2011, 10:13 PM | #20 |
494
Rep 1,922
Drives: 2021 G80 M3
subscribed.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
06-21-2011, 12:37 AM | #22 |
161
Rep 7,377
i have cancelled my order for the moment since i found out my thermostat is not working correctly. gonna first replace that . I also might need to put money on different parts related to my AT ...
