BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > jumping another car using jump leads
      06-08-2011, 06:54 PM   #1
Brennan
'The Godfather'
Brennan's Avatar
No_Country
108
Drives: SAAB 9-3 Aero TTiD
Just wondering is there any problem using jump leads connected to the battery terminals of my e90 to jump start another car that has a flat battery?
My dad thinks the e90s have surge protectors or something like that (i wasnt really listening to him haha) so they wouldnt be any use to jump start a car
Just want to clear up this debate with him lol
      06-09-2011, 01:36 AM   #2
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
You certainly can, but you're better of using the terminal posts designed for this purpose rather than connecting straight to the battery. Clearly described in the manual how to jump-start another car or to be jump-started yourself.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      06-09-2011, 02:11 AM   #3
Giff
Giff's Avatar
Drives: E90
I only saw the first words of the thread title and got really excited..
      06-09-2011, 08:32 AM   #4
Brennan
'The Godfather'
Brennan's Avatar
No_Country
108
cheers mate, i knew my dad was wrong
      06-09-2011, 09:34 AM   #5
HighlandPete
6659
Drives: BMW F11 535i Touring
As said, use the under bonnet terminals and follow the correct procedure of connection/disconnection.
HighlandPete
      06-09-2011, 01:11 PM   #6
Brennan
'The Godfather'
Brennan's Avatar
No_Country
108
guys which are the terminal posts?
      06-09-2011, 02:51 PM   #7
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
The one with the big red plastic cover is positive - near the drivers window wiper.
Clip the neg to anything solid on the bodywork nearby.
      06-09-2011, 02:58 PM   #8
Cafe.Racer
Cafe.Racer's Avatar
27
Drives: 320d Touring
Didn't work for me when I ran the battery flat once. Under the Big Red plastic cover is the positive, but the negative connection is a special long hexagonal "bolt" on the inside of the wing near the driver's side headlight.
Phil
      06-09-2011, 04:57 PM   #9
Shadow
Scotland
Drives: E90
This.
      06-10-2011, 04:25 AM   #10
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Yep, its tricky to get a good neg/chassis connection on little 'stub' they provide.
It just too small for the largish croc-clips you get with cheap jump leads.
You're better grabbing some big (unpainted) metal chunk of engine block or similar then you can get a good grip with the clips.
      06-13-2011, 04:11 PM   #11
Jules59
Jules59's Avatar
56
Drives: Still searching ...
Probably teaching you to suck eggs, but connect up the positives first - from donor battery to your car, then connect up the negatives - from your car to the donor. That way if you accidently touch the body with the free cable end you wont short out the batteries and weld the cable to your car or worse.
Jules
      06-13-2011, 04:54 PM   #12
m1bjr
m1bjr's Avatar
72
What are you guys on?
You can connect to ANY bare metal part of the chassis / engine and get an earth connection.
I did this only last week as it happens, to jump a bike. Used one nut on the turret top IIRC.
      06-14-2011, 02:51 AM   #13
doughboy
doughboy's Avatar
1545
Of course you can, you and I and others know that, but the 'official' ground stub is useless as said.
So anyone checking the manual (so not 100% with doing it anyway) will be shown a duff method.
Any nice chunk of unpainted engine will do
      06-14-2011, 05:46 AM   #14
Shadow
Scotland
Drives: E90
I don't know what leads & clips you're using - Monster Cable?
Maybe the 'official' ground point is different on mine (about 1" long bright shiny hex?), but it seemed to make better contact. The problem end was the other car (elderly honda)...
      06-14-2011, 06:16 AM   #15
doughboy
doughboy's Avatar
1545
Just £10 halfords regular jump leads, but the croc clips are wider than the stud is long so they only catch one side of the jaws
The jaws also have spikes specifically designed to sink into soft lead battery terminals (which is what the honda would have had??), so on a hard surface they have minimal contact area.
On the two times i've tried to jump other peoples cars from mine, the stud was no use, it just sparked a lot and smoke came off the clamp jaws as they overheated.
      06-14-2011, 06:43 AM   #16
Shadow
Scotland
Drives: E90
Right - I've seen that type of clip; like you say, they work best if you can get them onto the softer battery terminals. They would have worked for the Honda except the leads my mate had were too short to reach his battery even with our cars parked 2" apart!
      06-14-2011, 02:45 PM   #17
m1bjr
m1bjr's Avatar
72
http://www.telegraph.co.uk/motoring/...ump-ahead.html
Why I don't use £10 Halfrauds crap leads
