Rattling Exhaust Sound
06-07-2011, 09:51 PM | #1 |
23
Rep 197
Drives: Black Sapphire E92 335is 2012
Hey guys my 335i is just a hundred miles shy of 30K and I've been noticing an increasing loud clicking/rattling/clanking metal noise that seems to be coming from my factory exhaust. I thought maybe it had to do with the butterfly valve? But I'm not sure at all. I was reading up and I found something about a wastegate actuator failure? Does anyone have any information or past experiences? Anything helps. Thanks in advance!
2012 E92 335is -M Sport Package- 19in M Rims- Black Sapphire Metallic/ Coral Red / Glaciar trim, Rear diffuser. Black Grille, 5% window tint. K&N drop in Air filter. Scarlett |
06-07-2011, 09:54 PM | #2 | |
127
Rep 571
Really? Its the wastegate rattle that BMW designed to be normal so it will all drive us insane................. |
06-08-2011, 07:40 AM | #4 |
73
Rep 1,388
Yeah it really could be the exhaust. When my valve went bad it was most noticeable on a cold start. You just had to start the car cold and let it sit until the idle clicked down to a lower rpm. Sounded like someone was rattling a can of nickels back in the left tip. Dealer replaced the exhaust, then I disabled the valve
E90 M3 Space/Fox/6MT
E92 335i BSM/Saddle/6MT - Sold |
06-08-2011, 12:00 PM | #5 | |
23
Rep 197
06-08-2011, 09:56 PM | #7 |
23
Rep 197
I'll try it. Thanks
06-09-2011, 09:10 AM | #8 |
73
Rep 1,388
Note that unplugging it will not "fix" the issue by any means. If that valve rattling is actually your problem, disabling it will make it so the valve doesnt work and you wont hear it - but it will still be broken. If youre still under warranty (seems like you should be) and you want it to be fixed properly, just take it in.
THEN, after it gets fixed, disable the valve. Exhaust sounds better that way
06-11-2011, 06:25 PM | #10 |
23
Rep 197
What is it supposed to do originally? What is it's function?
06-13-2011, 07:32 AM | #12 |
73
Rep 1,388
Valve in the left exhaust is bad. Muffler will need to be replaced. Take it in if you're under warranty, or disable the valve if you're not.
06-13-2011, 07:44 AM | #13 |
30
Rep 679
got first muffler replacement a few months after I picked up the car...just dropped it off at the dealers today for the exact same reason (after 11 months owning the car). The technician told me that he shouldnt be advising that but plugging the actuator out will probably fix it. Needless to say I will not be sattisfied with such solution...
335 - Öhlins//Swift//M3 front suspension//M3 subframe bushes//Quaife LSD//AR Design Catless//Forge Intercooler//Alcon BBK//Goodridge//AFE//RPI//Fenders - SOLD M4-Mineral Gray/Full Shakir Orange/DCT/M Ceramic/M Adaptive Susp. |
