Today I seriviced my E90 and something horrible happend :( Please help me if you can.
06-06-2011, 03:57 PM | #1 |
100
Rep 551
Hello,
Today I serviced my E90 320d pre-LCI. Servide included : - engine oil and oil filter <- didnt even need a car jack for that, but to un-bolt oil filter cover was horrible, but managed it banging with a heavy hammer on a side of a spanner ;P - microfilter <- very easy took about 5 minutes. - screenwash <- a little bit tricky as there is no measuring gauge or note on a computer to let you know the level. I hope the liquid will not expand under temperature that much as I filled almost to the top lol. - air filter <- ohhh.... and there is my problem and question to you. I stripped most of the engine to get to the filter (took 35 mins.), but there was one bolt of of three for the filter box which I overturned and broke the top of it and had to put everything back as I couldnt do anything Very irritating, ohhh very !!! What can I do now ? I thought about drilling the bolt out with a long drill bit as the bolt is positioned in crap position. The picture underneath shows the air filter box I am talking about and three bolts for it. The bolt I am talking about is the top one on the picture : Please let me have some ideas of how to cope with it. I will hugely appreciate that. Thank you
06-06-2011, 04:29 PM | #2 |
72
Rep 797
Drives: BMW 320d Le Mans Blue
not easy to see from the picture, but don't panic. Is it the bolt that has snapped? Or the nut end?
If its the bolt then should be able to get one from BMW and the broken end might just wind out of the nut...... If its the nut end thats smashed again a part will be available |
06-06-2011, 06:28 PM | #3 | |
100
Rep 551
I thought of drilling through it or maybe weld some tool to it and get it out. Breaking the filter box is another option but it would be expensive and getting it out with pliers would be horribly hard as it is round allen bolt. Another idea is to buy 3 liter diesel engine and forget this horrible 2 liter one lol. What do you think about all of that ?
06-07-2011, 08:36 AM | #5 |
Weekend Rockstar
39
Rep 728
where in Manc?? I'm in Leigh
A slightly oversize imperial allen key may tap in to allow you to loosen it Some "easy-outs" can you get a dremel head to it??? cut a slot and then a flat bladed driver.......... Max
E92 M3 - Interlagos Blue and Black everything else!!!
06-07-2011, 09:47 AM | #6 |
Rep 130
Drives: Everywhere
If the cap head has sheared you will need to drill it out or if there is enough gap with the rest of the filter box loose to get a small hacksaw blade in under and cut it off, it does make me cringe to see your post tho banging spanners with heavy hammers for the oil filter is not good practice or thinking about welding something to an allen bolt sorry thats wrong but thats just me tho 24yrs as a marine enginner, fair play for doing the work yourself tho.
If a bolt is tight in future try using a ring spanner on the open end to give you more leverage rather than beating it or you will end up with a bigger problem. simon
I can resist everything except tempation.
06-07-2011, 03:24 PM | #7 |
Rep 5
Hi I have managed to undo all the bolts myself but the problem is removing the casing to get to the filter. Im stuck so I put in back together as I needed to get to work.
It just will not come out its loose but something is stopping it. |
06-07-2011, 03:46 PM | #8 | |
LSD - No, you're not seeing things
72
Rep 3,302
Couple of screws, leave the wire connected to the sensor too. In pic 8 its unbolted but resting back in place, but look carefully compared to pic 3 you can see the srews are out of the airflow sensor (black plastic part with a lead attached) Read this: http://www.bimmerforums.co.uk/forum/...cedure-t67584/ Steve
06-07-2011, 05:31 PM | #9 | |
100
Rep 551
Here is the air filter box and 2 out of 3 bolts holding it which are easy to unbolt: And as you can see these 3 allen bolts are in a hollow The 3rd one which I smashed is on the back of the air box, on the bottom of it and going there with your hands is impossible.
06-07-2011, 05:36 PM | #10 | |
100
Rep 551
The allen bolt inside is just round, because of many tries and I think a little bigger allen key wouldnt help. I really tried every tool. Its good idea from you to use a dremel and then screw driver, but the bolt is on the bottom of the gap, so I couldnt fit my hands in there. That is why I smashed it, just couldnt get enought power on a tool
06-07-2011, 05:44 PM | #11 | |
100
Rep 551
It is really hard to get my hands in the gap to unbolt it, so I would need very long tool to unbolt it.
06-07-2011, 05:47 PM | #12 | |
100
Rep 551
If you undone 3 allen bolts holding the air filter box, there is a strut brace above it, and that stops you taking air filter box out. These 3 allen bolts cannot be taken out as they are attached to the box somehow.
06-15-2011, 05:33 PM | #13 |
100
Rep 551
BMW E90 pre-LCI Saloon 318d / 320d air filter change.
Hello guys
On my second attempt I managed to replace the air filter on my 320d pre-LCI. The whole job took around 1 hour. The allen bolt I have smashed on my first attempt just could not be taken out trying almost everything, but that did not stop me! I could not do it on my own as one person needs to bend the air filter box so the other person can somehow put it in place. I am glad the plastic box did not break because of heavy bending. It costs 40 pounds at BMW Saloon. I have asked a BMW dealership how much it would cost to change the air filter excluding the price for the filter... I was told 132 pounds !!!!!!!! I asked, why ???? I was told it is not that easy and takes them 1 hour. For 1 hour of work 132 pounds, sorry but what the hell ?!!! BMW is rubbish to be honest with you. I hope the next generation coming out next year will be a lot better. Here are some photos I took : The job is not that hard to be honest with you. I figured everything out first time and second time was just matter of time. Do not be scared and use right tools the first time or you will end up like me ! Thanks a lot to those who helped me PS. There are 4 allen bolts for the air filter box. I made a mistake in my previous comments, sorry :P
06-15-2011, 05:56 PM | #14 |
258
Rep 3,815
congrats, I remember doing this on my e46 320D it was a right PITA, all good having a huge surface air filter but its so restricted it just gunks up on the front entrance bit and its a pain to clean. At least with LCI they went back to normal airbox. Now its 5 seconds to change/ clean it.
F30 335i M Sport - now departed
06-16-2011, 06:24 AM | #16 |
Ben
62
Rep 1,992
Holy mother of god
What a shit design I dont understand why it is so inaccessible. With a bigger engine and other extra bits the 6cyclinder engines seem to fit everything in and make it accessible. Surely they have even more space to play with in the 320d. I just pop a couple of latches to remove the air filter. |
06-16-2011, 08:09 AM | #17 |
258
Rep 3,815
I think hence since LCI models the airbox is now located in bottom left of the engine bay and its case of just 3 clips to remove the cover and change the filter
06-16-2011, 05:34 PM | #19 | |
100
Rep 551
I managed to change the filter magicly Ohhhh, thanks God its all over In 2/3 years I will get an engine from 330d LCI with 245BHP I hope my problems will be sorted...
06-16-2011, 05:38 PM | #20 | |
100
Rep 551
Why do they always shit up pre-LCI models hmmmm... I suppose to encourage people to buy newer cars
06-17-2011, 06:27 PM | #22 | |
72
Rep 3,302
if they are wielded by Wurzel Gummidge
