Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > 05 Build DRL deactivate
      06-03-2011, 07:36 PM   #1
arctic330i
arctic330i's Avatar
126
Drives: F15 35i
2014 BMW X5  [0.00]
2006 BMW 330i E90  [8.08]
2013 BMW 335is  [10.00]
Can I get a confirmation from somebody that they can code a 05 330i e90 to remove the daytime running lights? Mine is too old for the setting to be in the BC stalk.
I have been told only dealers with autologic can do this, can somebody please prove me wrong!
See my full mod list in my garage
      06-06-2011, 11:00 PM   #2
arctic330i
arctic330i's Avatar
126
Drives: F15 35i
2014 BMW X5  [0.00]
Just to bring some closure to this lively thread, for an 05 build you can not simply code out the DRL's. They must be deactivated by the dealer or a shop with the Autologic software.
FYI, Lutz Performance in Tampa FL has this expensive tool and I can't wait to try it out!
      06-08-2011, 09:42 PM   #3
Wissam
20
Drives: 2007 e90 328I
I did it on a Canadian model, 330 build 06/05...in "FRM" submodule, look for TAGFAHRLICHT_ECE and change to nicht_aktiv...this turned off the high beam as DRL...
      07-24-2011, 02:49 PM   #4
bumere90
Grozniy
177
Drives: Carless
^ I tried this yesterday and it didn't work.
-fatman
      07-25-2011, 08:52 PM   #5
wilczy
wilczy's Avatar
Drives: 2006 E90 330i
Wissam is right.
Its in FRM and option has to be
TAGFAHRLICHT_ECE
nicht_aktiv
I did it on mine US model. ON and OFF. Finally left it OFF.
There is also 2 other places to enable DRL dimming and Hi Beams but TAGFAHRLICHT_ECE is "main switch" I believe.
I can provide more info if you like.
Hope it works for you.
      07-25-2011, 09:28 PM   #6
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
Yep that is the line.
after you code it, turn the car off and lock it and then start it after 15 seconds.
      07-25-2011, 10:29 PM   #7
bumere90
Grozniy
177
Drives: Carless
After 3rd attempt I was able to disable DRL. However, when I insert the key and press start, my AE's flicker as if they are coding. Is this normal?
-fatman
      07-25-2011, 10:33 PM   #8
DESI4life10
201
Yes..it`s because of the cold/warm checks.
I am guessing you have led angel eyes. The current sent to check the condition of the bulb is not enough to turn on halogen lights, but is enough to turn on the LED. The results is you get flickers from the Angel eyes.
You can disable the warm/cold checks for the angel eyes through the frm module. Take a look at the spreadsheet for the line to disable.
      07-25-2011, 10:35 PM   #9
bumere90
Grozniy
177
Drives: Carless
^ Thanks, I'll do that tomorrow.
Here is a vid
-fatman
      07-26-2011, 03:29 PM   #10
Elliott@DetailAddict
300
Drives: E90
^as Desi said... just the cold check working.
      07-26-2011, 04:42 PM   #11
Dracon
555
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
You should be able to remove $896 from the VO and it should disable the DRL.
You won't be able to enable/disable via the BC on older models because the software simply didn't support it at the time.
      07-26-2011, 08:46 PM   #12
woodpecka
woodpecka's Avatar
68
Drives: E91
So on the 05-06 build it's possible to deactivate the halogen DRL but is it possible to activate it with the AEs?
I haven't found how if it's the case.
      07-27-2011, 09:38 PM   #13
bumere90
Grozniy
177
Drives: Carless
my AE's are constantly on when I turn the switch
-fatman
      07-27-2011, 09:56 PM   #14
woodpecka
woodpecka's Avatar
68
Drives: E91
Can you get them on during the day with the automatic lights?
What did you changed?
      07-28-2011, 07:14 AM   #15
bumere90
Grozniy
177
Drives: Carless
Yes! All I did was change TAGFAHRLICHT_ECE to nicht_aktiv and ola. My AE's can run as a DRL without low beams
-fatman
      07-28-2011, 07:49 PM   #16
woodpecka
woodpecka's Avatar
68
Drives: E91
Thanks!
I can found TAGFAHRLICHT_ECE in my FRM file so this make sense.
In the google code spreedsheet there is only TAGFAHRLICHT_ECE_1 documented, should we add TAGFAHRLICHT_ECE?
Also, anybody know what is DEF_TAGFAHRLICHT_ECE_CKM and UNP_TAGFAHRLICHT_ECE_CKM ?
      01-26-2012, 07:39 PM   #17
woodpecka
woodpecka's Avatar
68
Drives: E91
I have change TAGFAHRLICHT_ECE to nicht_aktiv and I got no light or AE during the day with the automatic mode.
Pls can you share me your FRM file to compare?
      01-26-2012, 08:29 PM   #18
bumere90
Grozniy
177
Drives: Carless
put into middle position and see if your AE's light up
-fatman
      01-26-2012, 08:39 PM   #19
woodpecka
woodpecka's Avatar
68
Drives: E91
Yes this work on the parking mode. Did you get it on the automatic mode?
