2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes All 21" Wheels F10 Owners
      05-30-2011, 07:03 PM   #1
EL MEJOR
ALLDAY
EL MEJOR's Avatar
55
Drives: 2013 M6 convertible
I've noticed almost all threads that speak of 21" rims, all have done custom springs/coil overs on their f10. Is this absolutely necessary? Or is it just for looks? Also does this mean that if it's not dropped the 21" will fit better meaning more space between tire and body of car? Input is much appreciated thanx.
Note: just spoke to my dealer today and told me end production is June 9. And should be here by June 20's... So i have about 3 weeks or so to make up my mind and order the wheels and tires to have them just in time.
If you have 21" wheels please leave you feedback on your experiences.
2017 X5M
      05-30-2011, 07:16 PM   #2
mlai
mlai's Avatar
Hong Kong
166
Drives: 650GC/E93M3/Lexus LS600HL
Where in NY state do you reside? If in NYC..... You may want to order an extra set of 21" because the potholes there will kill your rims in no time
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      05-30-2011, 10:06 PM   #3
EL MEJOR
ALLDAY
EL MEJOR's Avatar
55
Yes in NYC awe don't say that! That's my fear. I'm already picturing how will I drive once I have it. I was even thinking og going with 295/30rear and 255/35front instead of 295/25 and 255/30 just to have that extra meat on the tire but i don't know if I will have the room although I feel I can since Im not lowering it and I've seen others lower it after they put 21" wheels and they claim no rub...
2017 X5M
      05-30-2011, 11:47 PM   #4
78mao
78mao's Avatar
Taiwan
133
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [1.00]
the gap between the wheels and the car was just wayy too big that u just have to lower the car for sure!
i have 0 rubbing after my first set of springs and now Im on coils even more slammed with no rubbing at all as well.
      05-31-2011, 10:16 AM   #5
DieselWeasel
Drives: '11 335d|'11 535i|'13 X3 3.5
Already did the test fit with my new wheels. 245.35.21 and 285.30.21 fit perfectly but I'm not going to use that setup. I'm going to use 255.30.21 and 295.25.21 as car is lowered on ACS suspension and it just looks better with the shorter profile tire. There is room to go taller than the 30 and 25 series if your wheels are made specifically for the car.
      05-31-2011, 12:40 PM   #6
EL MEJOR
ALLDAY
EL MEJOR's Avatar
55
Thanx Diesel. I think i will go with the 30/35 set up. although i noticed that 25/30 are like $200 cheaper per tire than the 30/35 setup. Hmmphh something to consider as well since the rims are already 3k+ ahhh these are going to be the longest 3 weeks ever!
2017 X5M
      05-31-2011, 10:25 PM   #7
DieselWeasel
Thanx Diesel. I think i will go with the 30/35 set up. although i noticed that 25/30 are like $200 cheaper per tire than the 30/35 setup. Hmmphh something to consider as well since the rims are already 3k ahhh these are going to be the longest 3 weeks ever!
Ha true. I believe Hankook had a really nice deal on 245.35.21 and 285.30.21 about two weeks ago from Tire Rack. The only car that uses these sizes stock is the Alpina B7, thus the slim pickings and the higher price. Be careful with your setup, I'd recommend 21x9, 35 to 38 offset to clear the upper control arm on the front with a 245.35.21. It's close but worked with my setup. The rear is no problem at all, 21x10.5 with around 40-45 should be good.
Pics to follow Friday.
      05-31-2011, 10:29 PM   #8
IE92
154
Drives: 2015 F80 M3
DieselWeasel and El Mejor, what wheels did you order?
      05-31-2011, 10:51 PM   #9
EL MEJOR
ALLDAY
EL MEJOR's Avatar
55
Thanx for the advice. I actually went to my dealer today and he told me that my 550 is almost done production and will ship sooner than june 9 as was expected so i might get it before june 20's!!! **crossing fingers** Im hoping this works! Awesome cant wait to see ur pics!
2017 X5M
      05-31-2011, 10:53 PM   #10
EL MEJOR
ALLDAY
EL MEJOR's Avatar
55
havent ordered none yet as Im undecisive but the wheels im considering are the F01/F07 style 312 21". only thing is their offset is 33 front and 44 rear. and measures 8.5" front and 10" rear. Dont know if the offset will be a problem?.. What are you working with?
2017 X5M
      05-31-2011, 11:53 PM   #11
IE92
154
Drives: 2015 F80 M3
I have a set of 21" Rennen wheels on order and I should have them in a few weeks. Right now I am on my stock 17's. I read your earlier posts, and if you are not going to lower your car then I highly recommend you go with 19's or 20's. Cars tend to look really bad when the fender gap (space between the tire and the fender) is wider than the tire itself. Good luck with whatever you decide though!
      06-01-2011, 01:10 AM   #12
luigimaster24
luigimaster24's Avatar
Mexico
159
Drives: 2020 X7 M50i & 2021 X6M Comp
If I'm not mistaken , the F01/F07 style 312 in 21'' would fit the F10.
However, with 21x8.5 et33 fronts and 21x10 et44 rears, which would be the equivalent to 21x9 et39 and 21x10.5 et50 the fitment would be very conservative and I would certainly recommend you use 10mm spacers for the fronts and rears for a close to flush fitment.
      06-01-2011, 06:50 AM   #13
DieselWeasel
www.dub1wheels.com
Ordered the Dub.7 in polished and brushed center with cutout for oem
BMW center caps. Will probably have the lips painted black in a few weeks. 21x9 and 21x10.5
      07-01-2013, 10:46 AM   #14
bobseltenrich
bobseltenrich's Avatar
Drives: 2011 BMW 550i
2011 BMW 550i  [0.00]
21" Styling 312s for my F10 550i
I have someone here in Germany selling a set of 21" 312s but the wheels sizes are 8.5x21 ET 25 and 10x21 ET 41. They have 245/35 and 275/30 tires. Would I have a problem with the fronts?
Thanks
      07-01-2013, 01:49 PM   #15
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
I had 9" front with 25 offset so you will be fine.
      07-01-2013, 07:55 PM   #16
happymeal
Drives: F10 550i
+1 on the OP, i have 21" wheels, 21x9 in the front and 21x10.5 in the back. i was told to install 245/30 in the front and 295/25 in the back.
i wanted to go with 245/35 and 295/30, since i am not on springs, but decided to go with OEM tire recommendation.
if there isnt a fitment issue, i would really like the thicker side wall, for peace of mind.
      07-01-2013, 08:42 PM   #17
MELLOWYELLOW06
331
i got 255 up front and it works great
5post
