Comfort Access Remtote Not Detected?
05-27-2011, 10:44 AM | #1 |
Aficionado of All Things Vroom
177
Rep 1,215
So I searched and found plenty of threads about general issues with tint reducing comfort access range/consistency, but didn't see anything quite like the issue i'm experience now.
Aside from often not locking/unlocking ( which I attribute to the tint although it has gotten considerably worse over time), I will now get an error 1/10 times I start the car that the key is not detected and engine start is not possible. I've also gotten this with the motor already running, like it can't sense the remote anymore. keeps making me nervous while I'm driving that the system is going to screw itself up not sensing the key. Is this something anyone else has experienced/ would a simple battery change or key reprogram likely correct the situation? I don't care as much about the lock/unlocking issues, as I've had problems with keyless entry and tinted cars before. and of course the car waits until I have tons of shit in my hands and I'm trying to open the trunk or back door to not work. thanks for the help!
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
05-27-2011, 10:50 AM | #2 |
263
Rep 1,225
Start with the simplest thing first. Change the battery in the key.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
05-27-2011, 11:20 AM | #3 | |
14
Rep 158
Had the same issue.
2008 BMW 335i ; premium package ; sport package ;
05-27-2011, 11:55 AM | #4 |
177
Rep 1,215
so if I just change the battery I won't need to have the remote reprogrammed correct?
05-27-2011, 01:59 PM | #6 |
177
Rep 1,215
LOL maybe I should have been more specific with my last comment. I meant that simply removing/replacing the battery from the remote won't require a reprogram, correct? like it won't need to be resynced to the car or anything.
05-27-2011, 03:23 PM | #7 | |
124
Rep 5,627
But no - the remote battery is plug & play: 1. Buy a CR 2032 battery (ca. $3.00 at Radio Shack) 2. Remove the key from the CA fob by depressing the serrated area & pulling the key out. 3. Pry off battery cover. 4. Remove old battery - note the polarity. 5. Insert new battery - maintaining correct polarity. 6. Snap battery cover back in place. 7. Re-insert key. 8. Repeat every 2~3 years or as needed. Tom |
05-27-2011, 03:25 PM | #8 | |
177
Rep 1,215
05-27-2011, 06:13 PM | #9 |
124
Rep 5,627
05-27-2011, 07:29 PM | #10 |
103
Rep 1,392
This is kind of a somewhat related question. Let say you start your car with the key inside your pocket. Walk away and a thief get in and drive off with your car. Does the engine shut off after certain distant from the key?
Sorry to be stealing your threat
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
05-27-2011, 07:34 PM | #11 | |
177
Rep 1,215
it's funny you say that. i've always wondered the same thing myself. Like, if you have your fob in your pocket and were to be carjacked. no worries about jacking the thread. I changed the battery today as per Tom's recommendation so we'll see if the problem is solved!
05-27-2011, 07:35 PM | #12 |
Been There, Done That.
655
Rep 4,728
Doesn't the car tell you that the key battery is low? My sisters 650i chimes and a display comes up on the dash saying key battery low.
05-27-2011, 09:43 PM | #13 |
124
Rep 2,554
I believe the engine doesn't start if the fob is outside of the car.
05-27-2011, 10:01 PM | #14 |
Mr. Monaco
155
Rep 4,197
You're right it should display on dash of it's low
05-28-2011, 04:30 AM | #15 | |
Where'd my VTEC go?
481
Rep 6,067
FYI, you can lock the car with the engine running should you have to walk away from it for whatever reason.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-28-2011, 11:30 AM | #16 | |
124
Rep 5,627
With two CA BMW's, I found that one gave the warning icon when the battery would still function (albeit only 80% of the time) and the other gave no warning with the CA functioning only about 25% of the time. Tom |
05-28-2011, 11:39 AM | #17 | |
16
Rep 181
just change the battery in the remote. it should work then, if not just put the fob into the slot every once in a while. the manual states that if a key fob sits for over a year that it could lose it rechargeable power and it is recommended it be used twice a year if you have multiple keys. in the manual its page 27 and 28. hope this helps if not grab the sledge hammer |
05-28-2011, 01:01 PM | #18 |
1917
Rep 13,109
CA does not have rechargable battery in the 3 series
The battery could be low(key fob battery) and you would not get maximum range or function.
and it would not give you a warning message. I wish the car would turn off when you walked away there have been cases here were someone left the car running locked it and it idled the whole day or till the gas ran out. Also anyone could break in and drive away. This usually happens when you allow someone else to borrow the car there is definitely a learning curve to operating the electronics especially with CA. |
05-28-2011, 01:58 PM | #19 |
Rep 57
Don't forget to charge your key here and there as well, CA is nice but you have to put the key in the ignition to charge it sometimes.
I'm chromed out bitches!
05-28-2011, 03:16 PM | #20 |
13
Rep 229
Lies CA remotes aren't rechargeable. Just non CA.
2007 335i, Space Gray, Black/Alum, Sports, Prem, CA, Navi, iPod
05-28-2011, 03:18 PM | #21 |
Rep 74
05-28-2011, 09:03 PM | #22 |
16
Rep 181
Comfort access key fobs are not rechargeable. Battery only. Makes no difference whether you put in ignition or not.[/QUOTE]
I learned something today.
2008 335XI E90 // SPORTS // PREMIUM // COLD WEATHER // LOGIC 7 // BLACK DAKOTA LEATHER ON BLACK SAPPHIRE // I-DRIVE // VMR V701 // LED BLACKLINES SMOKED // KWV1 // INJEN DCI // JB4 // LED ANGELS //
