Wheel upkeep
05-26-2011, 01:24 AM | #1 |
Rep 35
Wheel upkeep
Any recommendations on what type of wheel cleaner to use on hyper silver wheels? Also, what type of tire shine doesn't damage the wheels? thanks!
05-26-2011, 08:58 AM | #2 |
Rep 194
I just use soap and water to clean the wheels. As long as you stay on top of it that is all you should need. For the tires I use this:
http://www.detailedimage.com/Optimum...P283/32-oz-S1/ |
05-26-2011, 10:03 AM | #3 |
360
Rep 5,052
I'd suggest a pH neutral wheel cleaner:
SONAX Wheel Cleaner Full Effect - Great cleaning power yet completely safe Chemical Guys Citrus Wash Wheel & Rim Cleaner - awesome value For the tires we have several awesome water based options that look good and are good for the tire: Optimum Tire Shine Poorboy's World Bold 'n Bright If you want a more permanent tire shine that looks amazing for several months check out the TUF SHINE Tire Appearance Kit. Let me know if you have any other questions. Greg @ DI |
05-26-2011, 11:37 AM | #4 |
Trance Life
315
Rep 4,706
To save you some money - if your wheels are already new and in great condition, don't go straight for the wheel cleaners, use soap and water on a weekly basis, and your wheels will look new for a long time. Make sure to get into the wheel barrel with a brush or mitt. And apply a sealant or wax to the wheels to make them easier to clean.
I've had pretty damn good results with Meguiar's Endurance Tire Gel...and it should be available OTC...
Vanguard V2 Exhaust//Vishnu DCI//ACM Angel Eyes
05-26-2011, 03:06 PM | #5 |
Search or ban.
31
Rep 364
For tire shine, preferably you want to use something that isn't silicone based, as these products actually end up drying the rubber out, causing premature aging (cracks, discoloration). As Detailed Image said, try the brand Optimum. I've never tried the gel that he recommended, but I have tried Optimum Tire Shine. Because they are both water based, the dressing can actually be absorbed into the rubber, which in turn conditions the tire. It may not look as intense of a shine with one coat as silicone based dressing, but you can apply multiple coats depending on how glossy you want the tires to be. Be sure to use a cleaner on your tires prior to using these water based tire shines, as they won't work well if you currently have a silicone based protectant on there already.
For that, I'd recommend Sonax Full Effect or P21S Gel Wheel Cleaner. Both are ph neutral and can be safely sprayed on both your wheels and tires. For more stubborn contaminants, go with Sonax. For lighter, everyday cleaning, the P21S works great. I switch between both just as a precautionary measure, even though both are considered noncorrosive and ph neutral. Going with the rule of thumb in detailing, use the least required for the job (especially when you're working with $3000+ wheels). Regardless of which you choose, they are both very effective in removing brake dust, grime, grease, etc. The sonax is pretty cool because it turns red once it activates, letting you know that it's breaking down the contaminants on your wheels. The P21S is gel based, so it adheres to the surface better than traditional spray. After spraying/geling, agitate with a soft brush, then rinse thoroughly. Wipe the wheel & tire dry, then you're ready to use the tire dressing that I described earlier. Btw, its ideal to do each wheel one at a time, if time allows. Hope this gives you a little more insight on wheel/tire cleaning & dressing.
'06 325i Black // iDrive // Cold Weather Pkg // Terra Dakota Leather // Lux 5.1 AE LED // Comfort Access // Premium Pkg // Ray's Sebring 19x8.5 & 19x9.5 w/ 245.35.19 - Mich. PS2 & 275.30.19 - Conti. SportContact2 // Front Bumper Splitters // MSD Air Scoops
05-26-2011, 03:27 PM | #6 |
12
Rep 433
I'd recommend Sonax all the way. Prior to a few weeks ago, I tried a variety of products (p21s, chemical guys diablo gel, mothers wheel cleaner, just to name a few) which were only okay. The results obtained with Sonax, however, were simply astonishing. I had baked on/caked on brake dust inside of the wheel that I could not get out. I let Sonax dwell for ~3 minutes and agitated with my EZ detail brush and the brake dust melted away. Simply amazing!
f30 335i: Current
e92 335i: Sold 10/29/2015 e90 328i: Sold 12/7/2013 |
05-26-2011, 07:27 PM | #7 | ||
13
Rep 188
Mike |
05-26-2011, 08:48 PM | #8 | |
127
Rep 6,773
05-26-2011, 11:18 PM | #9 |
149
Rep 6,604
Drives: e92 335i
just do an upkeep on your wheels weekly to prevent the brake dust from piling up and from baking onto your wheels.
05-27-2011, 04:49 AM | #10 |
13
Rep 506
I just keep up on the wheels, with soap and water. But if I can't the sonax full effect is the best, it melts away the brake dust. Spray wait a few minutes and agitate with a brush and rinse.
05-27-2011, 10:59 AM | #11 | |
24
Rep 1,244
This is exactly what I do/use and it works like a champ. Personally, I found it to work every bit as good as Sonax. Actually, I saw no benefit to using Sonax over this method. |
06-01-2011, 04:53 PM | #12 |
Long Time Admirer, First Time Owner
18085
Rep 9,381
Spend a few $ on something like PB Wheel Wax and you can get by most of the year with just soap/water. Thanksgiving weekend I now pull each wheel, clean/clay it, then put on a new couple of coats of PBWW. Something as simple as checking my tire pressure reveals a totally clean rim where my fingers happen to touch removing the valve cover.
06-01-2011, 07:15 PM | #14 |
BimmerPost Supporting Vendor
2002
Rep 6,916
I have not seen discoloration on the wheels, did you make sure you rinsed all of the Sonax off the wheels?
Sonax Full Effect would be the way to go. To make it even better we have been using Optimum Opti Coat on wheels and it will give you a permanent coating on the wheels just up keep them and you should be good to go. I have found it to do a great job of brake dust settling on the coating and not on the clear of the wheels. |
06-19-2011, 05:45 PM | #15 |
21
Rep 780
Use the soapy car wash bucket after you are finished washing the car with an ez wheel brush, I also use a mothers powercone. Wax the wheels when you wax the car and when/if you swap them out for winter.
