BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > install M aerodynamic kit on 335xi - problem with fog lights
      05-20-2011, 04:28 PM   #1
lbouchard
Drives: 335XI
I have completed the installation of the full M aerodynamic kit on my 2007 335xi. I now have an error with what i believe is the fog lights.
anyone can help me out? what parameters need to be updated by my dealer? and to what value?
thanks
      05-20-2011, 06:03 PM   #2
Elliott@DetailAddict
300
Drives: E90
You would have to have them code out the warm and cold testing on the front fog lights to not active.
Or come on down to the Bay Area and we'll take care of you
      05-20-2011, 08:05 PM   #3
lbouchard
Drives: 335XI
what is "wrong" with the M fog light? what is the difference?
can I simply change the light bulb to a different type to avoid recoding ?
      05-20-2011, 08:54 PM   #4
300
Drives: E90
Is it an OEM kit?
We could see if there was a valid OEM retrofit K word to add to your VO.
Who did the install?
      05-21-2011, 08:30 AM   #5
lbouchard
Drives: 335XI
yes, this is the OEM Aerodynamic kit
The install was done at a local body shop.
      05-21-2011, 08:36 AM   #6
bulldog_yyc
bulldog_yyc's Avatar
130
Drives: GT3RS
you need a 9006 harness and bulbs with that kit - perhaps the shop did not do the harness conversion properly (polarity)? Do the fogs turn on at all?
      05-21-2011, 12:52 PM   #7
300
Drives: E90
^Exactly.
It seems like there is a hardware issue somewhere.
I'd get that solved before looking into error deletes with coding.
      05-31-2011, 06:57 PM   #8
lbouchard
Drives: 335XI
yes, the fog lights work very well. I can turn them on/off with the switch.
the error in the cluster is a yellow builb with a "!" in the middle. the manual says "bulb of exterior lighting system failed" I have check everything, all bulbs are ok. the only thing that have changed is the new fog lights from the OEM M aero kit.
