2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes possible compact spare for F10
      05-20-2011, 10:19 AM   #1
RH512
Drives: 535i xDrive, C4S cab
Has anyone tried the wheel from the X5/X6 spare to see if it fits and clears on an 535 or 550?
Would need a different size tire and a centering ring but those can be obtained.
This tread talks about doing it for an M3, just wondered if it would fit our cars??
http://www.m3post.com/forums/showthread.php?t=253769
Any experience or info would help.
Thanks
      05-20-2011, 10:27 AM   #2
EV0LVE
EV0LVE's Avatar
41
Drives: F10 535i SG
i wouldn't expect the suv tire to fit on the f10, but perhaps the e60 will.
      05-20-2011, 12:17 PM   #3
RH512
E60 will not I'm afraid, others have tried, pretty much ruled everything else out except this possibility. Tire would be too large from the SUV but correct size tire is available. Center hole too large but centering ring fixes that.
Hope someone has or can try it.
      07-03-2011, 09:32 PM   #4
Russ
Drives: BMW 550xi
.. if cheap is the objective then maybe buying an aftermarket wheel would be better..
      07-05-2011, 10:36 AM   #5
RH512
Objective is saving space in the trunk. if a compact spare wheel and tire can be found then keeping a spare in the truck is more practical.
I currently have a full size spare on a full size wheel. Cheap wheels in a full size are available...yes. The idea was a five inch wide wheel (compact spare) vs a eight inch wide one with the appropriate tire and about 40% space saving in the trunk.
      07-06-2011, 09:28 AM   #6
pyramid
Indonesia
Drives: Serpent S966
Various Various  [0.00]
What's wrong with this? swap to 135/90/17 tire to get 674.8mm diameter (factory is 680mm).
http://www.realoem.com/bmw/showparts...49&hg=36&fg=95
      07-06-2011, 11:35 AM   #7
Keto
Keto's Avatar
73
Drives: F80 M3
2015 BMW M3  [10.00]
That looks promising.
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed
Bavsound Stage 1 : V1 Savvy hardwired : Self-coded
      07-06-2011, 01:10 PM   #8
RH512
Could work! 17" wheel is minimum for F10. Just a question of it clearing the brakes and the offset aligning correctly to not rub at any point. Also hub diameter not too small. Have you tried it?
I had thought the X5/X6 being 18" wheel was a safer bet, total diameter with 155/70-18 is 674mm. Hub is too large but centering ring will fix that.
Just need real experiences on the F10 to determine.
      07-07-2011, 10:50 AM   #9
pyramid
Indonesia
I have not tried it, no intention to purchase yet. I just saw those in my local dealer.
Next week I'm bringing my car for m sport aero kit retrofit. If they still have that spare tire kit available, I will asked them to try the rim to see if it fits.
      07-08-2011, 04:10 PM   #10
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
What year X5/X6 were you referring to? The BMW X5 and X6 wheels are actually a bit funky to be honest. BMW had designed various hub sizes for specific years/trim levels.
X5 E53 - 72.6 center bore
X5 E70 - 74.1 center bore
X5M E70 - 72.6 front/74.1 rear center bore
X6 E71/72 and M - 74.1 front/74.1 rear center bore
-Charles@VMRWheels
      07-13-2011, 10:39 AM   #11
RH512
-Charles@VMRWheels
I was looking at this part 36-11-6-768-861. Center bore can be accommodated with centering rings to match our F10's since they will be smaller.
Maxxis has a tire with the appropriate diameter.
Idea came from this thread: http://www.m3post.com/forums/showthread.php?t=253769
Any guidance you can give would be great!
5post
