03-27-2007, 01:07 AM | #1 |
Speed
65
Rep 407
Corner Balancing
Has anyone had their M corner balanced? I am debating but would like some feed back if available. I know it is designed to significantly improve the handling but I would like some first hand experiences.
03-27-2007, 06:25 PM | #2 |
//Mdicted
348
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
most folks that I know that gets them done are the ones that puts on coilovers, since you are messing with the dampening it kinda requires tweaking the car weight disturbution from what I understand. For it does need it on track cornering, but if you re just street why bother
06-27-2007, 05:14 PM | #3 | |
Rep 56
If you have coil-overs it is a must, and is one of the only reason one would get a coil-over IMO. The car will just feel so balanced and track completely flat into turns. There is also a plus. Because of the equal weight distribution you can change both tires on one side of the car at the same time with one jack. |
