Need help on new problem!
05-17-2011, 11:38 AM | #1 |
Rep 111
Hi guys. I own a 2006 325xi with 80k miles. Sometimes when i acceleraterate slowly, i feel i little surge of power or jolt forward. In the cold months, i also a little bit of idling issues, meaning that when back in neutral (6 speeds) the revs would just occiliate a little over the 1100-1300 mark! Yesterday, when i can home, when i start slowing down but just before i stop like 5mph, whether the car is in gear or not, i am almost stopped and again sort of a little jolt forward and a little thug. Feels like a transmission downshift slip feeling!! Notice the car is not in gear but on neutral!!! Thanks for the advice. Oh yes also, sometimes in winter the check engine light goes on for a day and then after 10 starts disapears! It has done that for 3 winters, i dont bother anymore, it goes away!!!
05-20-2011, 09:10 AM | #3 |
103
Rep 2,783
Rpm fluctuations can be cured with chevron techron fuel injector cleaner. As for your transmission, have you changed the fluid?
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
