320d gearbox oil
05-17-2011, 12:47 PM | #2 |
Rep 203
The carlube oil guide I have reckons 75W90 fully syn, 1.3L of it. Any good automotive parts supplier should be able to sort you out, just make sure its fully syn and not the regular part syn.
May as well do the diff whilst your at it, that takes 1L. |
05-17-2011, 03:27 PM | #4 |
Rep 203
From my view that can't be true. Its a gearbox, nothing special. Yes it is designed to work with the correct gear oil but its not exactly hard to get hold of the right stuff.
Unfortunately Audi oil doesn't exactly narrow it down for you but what I said previously will do the job nicely. You could use part syn oil but the gear changes won't feel as smooth and it may degrade the synchro rings at a higher rate than with fully syn. |
05-18-2011, 01:55 AM | #7 |
1397
Rep 8,083
Are you talking a manual or auto 'box?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
05-18-2011, 11:40 AM | #8 |
Rep 203
Good point. I was referring to a manual box.
Diff takes the same oil as a manual gearbox, i.e 75W90. |
01-16-2014, 06:19 AM | #10 |
46
Rep 891
Audi recommend 75w90 GL4 for gearboxes and 70w90 GL5 for diff's GL5 having a higher shear tolerance.
any of these oils will be reet: http://www.opieoils.co.uk/c-673-75w-90-gear-oils.aspx |
01-16-2014, 08:03 AM | #11 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Sorry but this is incorrect. Gearbox oil = 75W-80, diff oil = 75W-90. Putting 75W-90 in the gearbox will mean stiff/baulking changes on cold mornings...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
