BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Engine warning light.
      05-15-2011, 02:31 PM   #1
Bugsyt
Drives: E92 335i
Question Engine warning light.
Hi, all Had my 335i auto for two weeks. Just had engine fault warning light come on, yellow in dash warning symbol, and iDrive message saying engine fault, reduced power. Continued 60 miles slowly, no noise but definite power loss. When i stopped at home, and re-started the light went out.
Any ideas please. Can't see dealer until Monday.
      05-15-2011, 02:56 PM   #2
zltm089
zltm089's Avatar
244
Drives: 335i SE Coupe Space Grey
2006 BMW 335i  [10.00]
does it come on after a long drive?....keep testing it for a few more days....
not a good sign!
      05-15-2011, 06:54 PM   #3
neil@JuicedUpTuning
neil@JuicedUpTuning's Avatar
14
Drives: BMW 135i
CEL is a symbol for a whole range of issues. Only way to tell is to scan for codes using a code reading and deleting tool. BT Cable, BMS CT Tool or going to a garage.
      05-16-2011, 08:01 AM   #4
khurmit
55
Drives: '08 E90 M3
Did it come on the moment you decided to "UNLEASH THE FURY"??? or did it just randomly pop up as you were cruising at a steady speed?
Basiclaly mine did the same thing and got me a bit worried - codes etc read by BMW, turns out to be something to do with the Vanos Soleniod for the exhaust (hence why it only popped up under WOT, and continues to randomly pop up when I am "flooring" it).
Anyways after a bit of a search on the forums, turns out it's a simple 1/2 hr DIY job to replace the solenoid, which is in an easily accessible position.
I Just need to find out the price of the unit, then get it fitted - prob by my mate at BMW ;-)
Basically I just wanted to re-assure you that although it might seem catastrophic when you see the EML come on, there is light at the end of the tunnel.
Although your prob might be more serious than mine......
      05-16-2011, 08:35 AM   #5
muffking
Regular user
muffking's Avatar
224
Drives: F30 330D M-Sport Auto
+1
Get yourself a fault code reader. you won't need to spend much and it could save you a trip to the garage, or at least it will point you in the right direction if the a fault code was logged in the ECU.
      05-16-2011, 08:53 AM   #6
fastloop
40
Drives: E92 335i M Sport
Lots of possibilities here and as said without reading the codes it will be a stab in the dark.
Common causes:
  • Misfires (Bad spark plug, ignition coil, fuel injector. Bad DME software - I think progman versions v32-v34 had some bad adaptations that would cause misfires on Bank 1 (cyl 1-3) on longer journeys. Updating the software is the only way to fix these. )
  • Boost leak (Substantial leak, e.g. FMIC pipe popped off. Would trigger on WOT)
  • VANOS (Vanos solenoids may need replacing)
Get the codes read and let us know.
Does it disappear if your stop/start the engine, or leave it for an hour or two? Does the engine feel lumpy or doesn't run as smooth as normal? Most of the above issues are fairly easy to fix and not too expensive, but it depends on if you know a good indy and if you have a bit of patience. Dealers sometimes take the big hammer approach to this and replace a lot which is fine when you have warranty. Out of warranty, paying ~ £2K for 6 new injectors is no fun and everything else should really be tried before spending this kind of money.
      05-16-2011, 01:45 PM   #7
pjs
pjs's Avatar
274
Drives: i8
Coils, injectors, plugs, vanos solenoids, HPFP. Will be one or more of these based on my experiences.
      05-16-2011, 03:23 PM   #8
MEGA
Dieseasal
MEGA's Avatar
204
Drives: LCI E92 335d M-Sport
If you are out of warranty might I suggest you call Jason at BW chip tune (unless you know a local specialist)
He is very well skilled with these engines and can of course also read / interpret / delete as necessary the fault codes.
07831 103030
Tell him Dave / Mega sent you..
Previously: 2003 Peugeot 206 1.6 8v | 2006 E90 320d M-Sport, 19" BBS CH, Full Ice-cold JL audio install, August 2010 Total BMW 6 page feature car. | 2003 Nissan 350Z GT Coupe 286BHP
Now:2010 E92 LCI 335d M-Sport
      05-17-2011, 07:20 AM   #9
zltm089
zltm089's Avatar
244
PLUS ONE
      05-17-2011, 01:55 PM   #10
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
The VANOS code doesnt necessarily mean its a solenoid.
There is a known wear issue with the camshaft ledges, which cause loss of pressure I guess.
You will find the vanos gears dont position as quickly as they should as a result and you get a vanos tining error.
Sometimes low oil / oil surge / hard cornering on rough like track kerbs can cause it, or simply dirty lube.
Needs more info.
      06-08-2011, 03:23 AM   #11
tuningas
Drives: bmw 335i chipped
engine fault reduced power
hi everybody .i have bmw 335i e92...and today i had a flat battery,i was not driving it for a week...so i started car with the jump leads.and then went to the other town,i was going 150 miles per hour and then suddenly engine fault reduced power comes on my dashboard.i stopped with my car,turned off and started again it was ok while i not pushed the accelerator,so it comes on again...any suggestions?does it happend because of the flat battery?thanks
      06-08-2011, 04:38 AM   #12
fastloop
40
Unlikely to be related to the battery. You really need to read the codes with a BT, GT1, AutoLogic or other tool that will read BMW specific codes.
Common causes are:
- Bad ignition coils
- Fuel injectors
- Spark plugs
- VANOS fault
- HPFP fuel pump
- Boost leak
- etc.
Until you read the codes you won't really know.
      06-08-2011, 05:12 AM   #13
tuningas
but that light came straight after flat battery,when i was accelerating,and before never came on
      06-08-2011, 07:28 AM   #14
fastloop
40
AFAIK, the adaptations will not reset by just pulling the battery (or running it flat), so I think it's a coincidence.
Generally the Engine Fault is more likely to happen under load. So just idling or very light throttle will most likely not trigger the fault.
Is the engine feeling lumpy or is it running smooth? E.g. if it feels smooth then it could be that you have a boost leak. E.g. FMIC coupling popped off.
If it's lumpy then you probably have a misfire.
So all that's changed is that the battery went flat and you then did a highspeed run? If the following is not a typo then, the engine would have been under full load, so it could be a number of things.
What fuel are you using?
      06-08-2011, 07:45 AM   #15
tuningas
its running smooth,but i think its has less power..i am using unleaded.and when i am driving on small revs engine light does not comes on
      06-08-2011, 08:15 AM   #16
zltm089
zltm089's Avatar
244
From my own experience...the engine light came on, after 1 hour's drive...(non stop) ...and it did highlight the common issues...(injectors, HPFP, vanos etc) ...BUT THE WARNING LIGHT CAME ON AFTER A LONG DRIVE....so if you drive your car for short journeys, then you won't even know if you have these issues or not...
      06-08-2011, 08:17 AM   #17
zltm089
zltm089's Avatar
244
go for long test drives and short test drives....
I bet you, it will come on after long test drives....(i.e more than 1 hour) ...and i bet you it will be one or all of the COMMON faults of the 335i...
      06-08-2011, 08:19 AM   #18
zltm089
zltm089's Avatar
244
150 mph is quite fast... which motorway was this on?
      06-08-2011, 08:38 AM   #19
fastloop
40
You really need to get the codes read as everything else will be pure speculation. Find a local indy that have an AutoLogic kit and get them to read the codes for you.
If the engine is running smooth, then it could be that you have a boost leak and under light load the engine management finds that it can't build boost and throws an error.
E.g. have a look a the pictures in my thread below. This shows the IC connector that could be loose.
http://www.e90post.com/forums/showthread.php?t=373990
It's a splash tray off to get to the connector, but you may be able to see it from the top.
      06-08-2011, 08:45 AM   #20
fastloop
40
The issue with misfires happening on longer drives is known issue with the DME software. From memory ISTA versions between 31.1 - 34.0 had a problem with the DME adaptation that would cause misfires on bank 1 (cyl 1-3) on longer journeys. I can dig up the bulletin numbers if needed, but updating to the latest software will fix this.
      06-08-2011, 09:43 AM   #21
tuningas
it was on A1073 road m8,with 335i u dont need long way to achieve 150mph
      06-08-2011, 10:42 AM   #22
tuningas
can i have more information about this...u wana say i need to update some software or what?cheers
