BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      03-24-2007, 11:08 PM   #1
Sick Speed
Speed
Sick Speed's Avatar
63
Drives: 2008 335i E92 Coupe
E92 M3 Rear Diff
Does anyone know what rear diff is being installed in the new E92 M3?
Thanks in advance.
SS
      03-25-2007, 03:35 AM   #2
Alpin3_F30
Euro.Techniks-EAST
Alpin3_F30's Avatar
291
Drives: 2015 F30 328i
Thanks in advance.
SS
look it up you'll see which one it comes with. looks similar to the e92 aero kit with a twist
      03-25-2007, 04:25 AM   #3
E90Fleet
South Africa
1312
Drives: BMW
He's talking about the rear differential, not the body kit
BMW if you are reading, I need a job, Please.
      03-25-2007, 04:26 AM   #4
E90Fleet
South Africa
1312
Drives: BMW
No info on it yet
      03-25-2007, 05:26 PM   #5
Kafka
Drives: E46 M3 SMG
E 92 wheels and rims
The owner of one our more reputable after market shops indicated there was information available for the E92 wheel and rim specifications? I would like to buy some new rims for my E46 M3 that I could later transfer to the E92.
Has anyone any info on the E92 wheel and rim specifications yet?
Cheers,
K.
      03-26-2007, 05:00 AM   #6
southlight
Moderator / European Editor
southlight's Avatar
1512
Drives: X3M
Cheers,
K.
Take a look at this
Best regards, south
      03-26-2007, 10:11 PM   #7
Kafka
Drives: E46 M3 SMG
Good info on rims
Originally Posted by southlight View Post
Take a look at this
Best regards, south
Thanks South.
This is helpful, so I put in an order for some 19" rims that should be portable.
K.
      03-01-2008, 12:13 PM   #8
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
Here is a pic.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      03-01-2008, 01:28 PM   #9
GregW / Oregon
Commander-In-Chief
2119
Drives: 2023 M2 Coupe, 2020 GLE 450
Thanks in advance. SS
From the Aftersales Training document.
Final drive
In principle, the final drive is assembled in the same way as in the E6x M5/M6. It is, however, a separate new development.
The bevel gear shaft bearing is a frictionoptimized, double-row, angular-contact ball bearing. The gear ratio between the bevel gear and the crown gear has been adapted to the engine speed and gearbox ratio of the M3.
The final drive ratio is 3.85:1.
The 215 gear set (crown wheel diameter 215 mm) has been temperature and noise optimized. A friction-reduced gearing is used.
The housing of the final drive has been adapted to accommodate the double-row angular-contact ball bearing. The flanges for the propeller and drive shafts are the same as those used on the E6x M5 and M6.
The transmission housing end cover has been modified to ensure optimum gear oil cooling and bevel gear lubrication. The end cover has more ribs, which improves heat exchange. The internal styling of the end cover is adapted according to the size of the differential and the final drive ratio.
This Mfinal drive also has three bearings, with two front bearing and one rear bearing.
Fully variable M differential with locking action
This unique limited slip differential design is based on the E46 M3 and the E6x M5/M6 limited slip differential, where it is described in detail. The function of the limited slip differential has been adapted to ensure that the M3 develops
the best traction at different engine speeds and in every road situation
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      03-01-2008, 06:19 PM   #10
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
most important thing...100% wheel locking
m3post
