335d muffler delete
05-09-2011, 10:19 AM | #1 |
11
Rep 58
335d muffler delete
I just picked up an '11 335d. A few of my friends have diesel trucks and have deleted the mufflers on them and have measurable hp and torque gains. Has anyone done this on a 335d or X5d and with any gains? What do you think?
05-09-2011, 11:05 AM | #3 |
Some say...
239
Rep 4,296
Drives: Fresh
Try it and get back to us
I have exhaust and an intake... |
05-09-2011, 12:28 PM | #4 |
486
Rep 1,614
Most of the back pressure on the d is further upstream around the DPF. You cannot remove the DPF. So - if you remove the mufflers, you might succeed in making your car noisier, but probably won't succeed in gaining much power.
05-11-2011, 11:25 AM | #5 |
11
Rep 58
Thank you. That's more the answer I was looking for.
05-13-2011, 10:11 PM | #6 |
Rep 8
Actually you could remove the DPF and Urea injection if someone figures out an engine coding or external tuner that could remove the error codes associated with removing those items (of course that will void your warranty but I imagine some people don't care). It is very common with new diesel trucks (albeit illegal but impossible to enforce) where owners will take out the DPF and/or eliminate urea injection with a new engine coding. So far I haven't heard of a similar coding for the 335d US spec car though. Perhaps I'm wrong have any tuners managed to do any of the following on US spec diesel cars or SUVs?
1. delete the DPF with a straight pipe 2. eliminate/disable urea injection 3. bypass/delete the egr system 4. replace the swirl flaps with fixed plates 5. do any of the above and code to eliminate errors/check engine lights? |
05-14-2011, 05:25 PM | #9 |
11
Rep 146
05-29-2011, 11:01 PM | #10 |
Rep 8
Well has anyone heard of this? Seeing as nobody's warranty on a 2009 car has run out maybe these mods will become more common as the first warranties expire in 2013.
06-02-2011, 09:05 AM | #11 |
486
Rep 1,614
It's been done now across the pond: http://www.e90post.com/forums/showthread.php?t=535271
06-03-2011, 11:38 AM | #12 | |
Rep 8
07-19-2011, 04:40 PM | #13 |
145
Rep 2,383
I dont lurk in the UK forum much, but I just saw a discussion where they were discussing a 335d with DPF failure and forcing a "regen". I may be mistaken, but that seems to imply a DEF system. Is there a regen for DPF systems without DEF? Maybe they have some other way of purging the DPF of soot besides using DEF.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
07-20-2011, 10:42 AM | #14 |
Resident Diesel Junkie
56
Rep 1,070
Quasi, I think you may be a bit confused. The DPF regeneration is separate and independent from the DEF injection. The DPF physically catches particulate matter, which is periodically burned off. The DEF is injected into the exhaust to react with and neutralize nitrogen emissions.
The European cars must still undergo he DPF regeneration process even though they don't have DEF systems. |
07-20-2011, 01:50 PM | #15 | |
145
Rep 2,383
07-23-2011, 08:01 AM | #16 | |
191
Rep 6,110
Drives: Don't know yet!
In terms of performance gains you can expect approx 18-20bhp increase with little to no gain in the torque figure. My car is currently running at 363bhp and 500lbs torque measured on a Dyno Dynamics rolling road. My previous 335D running the same map and the stock exhaust system ran at 345bhp with the same 500lbs torque. Note: UK 335D's stock figures are 286BHP and 425lbs torque.
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience. |
12-07-2014, 09:38 PM | #18 | |
Rep 5
I've read that as long as the DPF is still on, removing the mufflers won't make much of a difference |
12-08-2014, 03:31 AM | #20 |
137
Rep 1,450
I have all 3 boxes deleted and Wagner FMIC and remap and just North of 380bhp and around 620 torque.....its a beast. When I had the remap tweaked after fitting the fmic and exhaust I gained a further 20bhp over the original remap on the car when stock
12-08-2014, 03:33 AM | #21 |
137
Rep 1,450
The sound is slightly louder and sounds more sporty in the cabin. The DPF and cats cut the volume so the 3 mufflers do very little
01-20-2016, 12:49 AM | #22 |
68
Rep 213
Bringing back a thread from the dead here...but does anyone have any sound clips of the muffler delete on the 335d? I'm thinking of doing this while I wait for additional exhaust options
