Air Bag Warning light ON, How do I reset it?
05-09-2011, 07:34 AM | #1 |
619
Rep 1,402
Stupid me, when I was installing the power sport seats, I disconnected the battery(very important) and disconnected the seat cables and changed out the seats. I connected the drivers seat cable and in my rush to try the seats out, I forgot to plug in the passenger seat cable, and I reconnected the battery and got a air bag light.
I can not reset it with my reset tool. Who can reset this? Is the dealer the only one? |
05-09-2011, 11:29 AM | #5 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
^ +1 for INPA if yours functions correctly.
05-09-2011, 03:40 PM | #7 |
252
Rep 7,089
Drives: '06 AW 330xi
Get the OBDII cable off eBay. It's $120 and you can code and do diagnostics.
05-16-2011, 05:48 PM | #8 |
lurker
26
Rep 222
Can you elaborate on this process? I've only had experience with INPA in terms of testing if it sees the EU with the ignition/battery status lights on when coding my '11 Mini cooper S but that's about it. I usually go into NCS expert to start coding after that. I'd like to help my friend out who installed aftermarket seats who didn't get the module that costs $200 or something and was hoping NCS expert coding could disable the airbag warning light. Thanks!
07-13-2011, 02:27 AM | #10 |
lurker
26
Rep 222
05-22-2012, 04:32 AM | #13 |
19
Rep 144
What can be done if it's not functioning correctly??
The dealer said they "reset" mine but every time I start it, it comes back on right away. Not sure if they are actually resetting it or they are trying to get me to hand over 700 bucks to fix it so that I don't try to reset it on my own? How do I even check to see if mine is faulty Sorry about the zombie post |
05-22-2012, 07:59 AM | #14 | |
886
Rep 9,097
What codes do you get? You need to find those, sort out the cause, clear airbag light and you should be good to go really.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
05-22-2012, 11:44 AM | #15 |
300
Rep 4,444
They may in fact be clearing it but as makkan said, if the reason the code is there is because there is a fault in the airbag circuit and you haven't fixed it, it will not go away.
04-11-2014, 02:33 PM | #16 | |
Rep 8
Inpa airbag F4 goes to another menu - need help
Anyone have the full sequence of reading and clearing codes in Inpa 5.02? Thanks |
04-12-2014, 09:35 AM | #17 |
93
Rep 713
Select your Chassis (E90)
Select (whatever you need - e.g. Airbag) Karosserie \ Airbag MRS5 Select F4 - Fehlerspeicher (codes) Select F1 - Fehlerspeicher lessen (read codes) Select F2 - Fehlerspeicher losen (Clear codes) |
04-16-2014, 09:33 PM | #19 |
Rep 8
Airbag reset
06-17-2014, 02:59 AM | #20 |
17
Rep 669
I did a seat swap but did disconnect the negative terminal on the battery and still got the restraint system malfunction error. I did a scan and is getting fault codes 93AE and 93AF, can anyone help me figure out what they mean and now to fix them?
06-17-2014, 04:32 AM | #21 |
93
Rep 713
This codes are realted to active headrests - left and right, if you swap a seats without active headrest then this code will show up. You probably should code this out using NCSexpert, but not sure what commend is responsible for this.
06-17-2014, 05:56 PM | #22 |
17
Rep 669
what are active headrests? What's NCSexpert? Can i use INPA? Sorry, i am not too familiar when it comes to coding.
