TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Please help INPA error messages and NCSEXPER problem!
      05-08-2011, 07:36 PM   #1
BMW4Life2112
BMW4Life2112's Avatar
14
Drives: E90
Background info: I have followed DIY guide exactly to the letter. Running Vista (which stinks), using clear ebay cable, 09/07 build date.
INPA Problem: I am having two recurring INPA error messages. One of the messages comes up immediately upon start up of INPA application and the other occurs when I try to read the airbag module. The message reads:
Warning
Registry Value Failed in SubKey:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/Serial
From searching numerous threads on all coding related forums I have found that the solution to the problem might be to go into the registry and change some values around, but I do not know how to go about this (exactly). The answer I found may be here (http://forums.bimmerforums.com/forum/showthread.php?t=1471268[/url]) post #5.
The second error message comes up when I try to communicate or read the airbag. When I go to Karosserie>Airbag (as in the DIY) pressing F5 doesn't do anything, but when I press enter button this error message comes up.
Variant checking
Group file: D_SIM
IFG-0018: INITIALIZATION ERROR.
Program will be stopped
Edit: I just decided to skip INPA step. But if you can still help me with a solution I would greatly appreciate it. Also, I found out what was wrong with NCSEXPERT. I was not running the program "as administrator" once I did this I had no problems and was able to code my e90!
      05-09-2011, 02:28 AM   #2
BMW4Life2112
14
Drives: E90
Please disregard this previous post, I found a solution to my problem via searching. Although I still don't know how to get INPA fixed. Oh well, but you can PM me if you need any help coding in San Diego area.
Search this Thread:
Advanced Search
