Not mounting downpipes to a bracket?
05-06-2011, 09:28 AM | #1 |
346
Rep 2,396
I got me some AA downpipes from a member off here and when installing I couldn't get the brackets to fit into that little bracket not too far from where DP's connect to catback.
Now I looked at AR downpipes and they don't have those brackets at all. Is it good idea to have DP's without any sort of support? I was thinking of do a quick spot weld on that bracket. |
05-06-2011, 09:30 AM | #2 | |
290
Rep 28,154
05-06-2011, 10:26 AM | #3 |
112
Rep 4,771
The stock downpipes are fairly heavy. I bet the bracket is there to reduce stress on the other components. If people can run the catted AR downpipes without a bracket, then you shouldn't have any issues using the catless AA downpipes without the bracket.
That being said, they really should still fit though... |
05-06-2011, 10:45 AM | #5 |
Roll Tide
591
Rep 2,345
I removed the bracket when installing my PLM downpipes. No issues.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306 |
