Are Eibachs still the preferred springs...??
05-05-2011, 11:19 AM | #1 |
30
Rep 664
I'm a bit impulsive and without any great thought just bought eibach's. However, from doing searches here I found mixed reviews.
Is it true that eibach's don't lower the rear?' I know with msport suspension that the car is lowered 10(r) and 15mm (f) but looking at my rears currently they sit pretty snug. Cheers Tiko
05-05-2011, 12:23 PM | #2 |
193
Rep 6,110
Drives: Don't know yet!
I think the Eibach Pro kit gives you approx 15mm on the rear and 20mm on the front (M Sport) from memory.
The H&R's are more aggressive in the drop and are too much on the roads here in Beirut , and I do speak from experience!
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience. |
05-05-2011, 12:46 PM | #4 | |
193
Rep 6,110
Personally I'd change both - springs and shocks, I believe the Koni's are a good match with the Eibach's, although I'm not sure which one (Koni's). Someone will be along soon to let you know though
05-05-2011, 03:45 PM | #6 |
30
Rep 664
I was hoping not having to spend on new shockers just yet. As it's likely I'll only be keeping the car for year max. Would the OEM shocks be suffice for now?
05-05-2011, 04:22 PM | #8 |
Lamininist
82
Rep 1,030
05-05-2011, 04:31 PM | #9 |
30
Rep 664
Thank you gents...
Will try springs with std shocks first. Just out of curiosity, can you recommend someone for koni's if I end up buying/needing them. Cheers Tiko
05-05-2011, 05:39 PM | #10 |
42
Rep 822
These guys are the UK importers for Koni - http://www.camberleyautofactors.com/home/index.php. I don't know whether you can buy directly from them though. I used POTN who have provided a decent service and price.
05-06-2011, 07:55 AM | #11 |
Lamininist
82
Rep 1,030
05-06-2011, 07:58 AM | #12 |
596
Rep 3,386
i think if you wanted to go any lower you would deff need to change the shocks. but since the eibach's are more conservative you should probably be ok for a year with just them and no aftermarket shocks.
05-07-2011, 05:22 AM | #13 |
118
Rep 2,216
Drives: E91 330d M Sport
I know dozens, and know of probably hundreds of people who run Eibach Pro-Kit springs with standard dampers, and I've never heard of a related problem.
Obviously, ideally you would change the dampers to something more suited to the shorter spring, but don't get yourself in a twist about it. It will be fine
Just how many Yorkshire sheep can you fit inside one exhaust?
05-16-2011, 08:29 AM | #15 |
Rep 2
I got Eibachs on standard springs with 19" 225's. The ride is pretty good, until you hit a big pothole! Definitely worth doing though, car feels planted and definitely more comfortable than I expected.
06-16-2011, 04:06 AM | #17 |
44
Rep 913
Thx
Be sure to post your pics when done!
. ..sweet torquin' diesel! |
06-16-2011, 04:00 PM | #18 |
Rep 87
I fitted Eibach pro kit springs with Bilstein B6's - spoke to the tech director at Eibach UK first and he turned out to know what he was talking about - they are an almost perfect match - guess what - they are developed together and may appear in the same box later this year- haven't turned it into a boneshaker either -
06-16-2011, 04:07 PM | #19 |
LSD - No, you're not seeing things
72
Rep 3,302
I have the revalved (by Hartge) Bilsteins and the Eibach coils.
Aparently they ship with these and Hartge just plonk one of thier lables over the part number I like them -hard but corners like a much smaller, nimbler car now. (H&R bars too here) Steve
