Steptronic Transmission -- No DS mode..?
05-02-2011, 04:31 PM | #1 |
26
Rep 303
So I was driving up from Philly to Newark Liberty International Airport Sunday morning and noticed that when I move the steptronic transmission over to the left, it doesn't switch to DS mode, it stays in D mode. I've noticed that its not only the electronic display malfunctioning because normally when I shift into DS mode, it will downshift one gear and that is not happening. When I shift manually, it does shift into M mode, but after not touching it for about 5 seconds (while still in M mode), it switches back to D mode. Has anyone ever had this happen? I'm on vacation in the Domican Republic, but plan to call my SA once I get home.
05-02-2011, 07:59 PM | #2 |
253
Rep 7,089
Drives: '06 AW 330xi
Yes. Search.
05-02-2011, 08:10 PM | #3 |
19
Rep 284
Just had this happen to my car few months ago, its the solenoid in the whole gear shift assembly. Bad news is they have to replace the whole assembly for $800+ unless your under warranty. And sorry to say there is no good news.
335i E90 | BMS DCI | Black Matte Grill | JB4 | Logic 7 | Sport | Premium | Cold |
05-02-2011, 10:21 PM | #4 |
26
Rep 303
Thanks for the info. I have 2 months of factory warranty remaining + 2 years of CPO. I should be covered, no?
05-02-2011, 10:26 PM | #6 |
137
Rep 1,475
Drives: 🚀
Garage List 2015 BMW M4 [0.00]
2012 BMW 335IS (SOLD) [6.84] 2011 BMW 335XI (SOLD) [4.66] 2008 BMW 335xi (SOLD) [10.00] |
yeah you should still be good.
05-03-2011, 08:33 AM | #7 |
19
Rep 284
I almost forgot I was out of warranty by 1500 miles and they covered mine under their goodwill program, so you should be good as well. And then all parts are covered by a 2 year warranty.
05-03-2011, 04:41 PM | #8 |
26
Rep 303
Another question that came across my mind - I bought this 2007 CPO 335xi this past february and this is already the third issue that has caused my car to go in for non-scheduled service. First, one of the rear windows stopped working and it needed a new regulator. Second, it needed a new muffler. Now this transmission issue. I'm starting l hear wastegate rattle so who knows when the turbos will go. Is this normal? Should I be looking into having BMWNA buyback my car? The idea of having my car in for service every single month is starting to concern me, especially as my warranties begin to expire...
05-03-2011, 07:37 PM | #9 | |
124
Rep 2,554
05-03-2011, 07:41 PM | #10 |
124
Rep 2,554
Sorry I can't edit, I'm on mobile
But I remember reading that the DS fails because a certain wire snaps and all you have to do is replace the wire, but you might as well get it done under warranty. I actually sparingly use DS because I don't want it to break once I'm out of warranty cause I'll be in off in college barely driving my car twice a month, all highway, and I won't be spending $800 to get into DS. |
05-08-2011, 09:48 PM | #11 |
26
Rep 303
Do you guys think this was caused by the fact that I switch between D and manual mode several times every time I drive my car? I'm assuming my higher than average use of the feature might be responsible for the damage, but don't want to have to stop using this feature in fear of it failing again...
05-09-2011, 08:45 AM | #12 | |
137
Rep 1,475
Drives: 🚀
05-09-2011, 11:29 AM | #13 |
14
Rep 710
I switch between D and DS a lot also and my DS mode broke a few months ago. Fortunately, it was still under warranty.
http://www.insiderpicks.com - The world's best stock picks.
08-13-2011, 01:09 AM | #14 |
130
Rep 1,291
Drives: E90 N52 & E92 m3
^^ whats their findings??? coz I just replaced my shift assembly and still dosent work
08-13-2011, 07:09 AM | #16 |
33
Rep 680
Drives: 2012 328i E92
08-13-2011, 09:23 AM | #17 |
My other ride is a Bianchi Infinito
96
Rep 2,767
Interesting. I'm going to search for the DIY in case I need that in the future. I too switch back and forth quite often.
08-13-2011, 09:40 AM | #18 |
103
Rep 2,783
Could be as simple as a crossed/crushed gear shift wire, search.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
08-13-2011, 01:13 PM | #19 |
130
Rep 1,291
I replaced my shift assembly and still didnt work. Maybe it needs to be reprogrammed
08-13-2011, 08:38 PM | #20 |
Bimmer n00b
66
Rep 649
I brought mine to dealer for same issue, but mine wasnt assembly it was cutted paddle shifter wire. When I had my dealer install steering wheel, they messed up the paddle wire. They had to put new paddles to fix the problem
08-14-2011, 12:13 AM | #21 |
130
Rep 1,291
I do not have a paddles though.
09-10-2011, 07:38 PM | #22 |
34
Rep 1,488
Those wire covered by the electric tape are tucked in a sharp 90* angles. That's where I found my cut wires and the shield on several others were broken. 20 minutes fix saved me so much $. I love this forum
