please help newb
04-30-2011, 12:36 AM | #1 |
"J" BONE
24
Rep 578
please help newb
i am currently running procede 12-17 autune and i want to try the 3-30 dic. so my question is when i upload the 3-30 can i just drive or do i have to select a map setting with the tach like 12-17? how do i know what it starts boosting at..sorry but i very new to this and if someone could please give me a run down on the dic maps that would be much appreciated. also with the mods in my sig and i run 94 octane what would be safe boost to run at. when i was running auto tune i was boosting between 14 and 15.
thanks
procede v5 rev3, afe dual cone intake, full catless exhaust with muffler delete, hm style carbon fibre lip, 235/35/19,275/30/19 satin black linea corse818, H&R sport springs, Vishnu charge pipe with forged diverter valves, matte black kidneys, mtec superwhite angel eyes and fogs, bms cdv ER fmic, VRSF coated DP. Vishnu pwm meth kit
04-30-2011, 01:16 AM | #2 |
PROcede it and Call it a DAY
17
Rep 167
The DIC map does not have the auto tune currently, but the torque on the car pulls like no other. You just upload and go, if you don't like it then you can just get the lastest auto tune map and reload. Simple as that.
04-30-2011, 09:31 AM | #3 |
65
Rep 1,705
you also need to reset all of your adaptations. The car will default to map 1, 13.5psi, but you can use the cruise control stock to swith maps (hold up or down).
map0 = valet mode map1 = 13.5 psi map2 = 14.5psi map3 = NA mode (do not use with DIC maps, it does not functon properly) Follow the directions that come with the downloaded maps/firmware
04-30-2011, 09:33 AM | #4 |
184
Rep 2,320
it depends what kind of v5 he has pro version or enthuasiastic, cos enthusiastic version has only map 0 (valet) and 1 map (autotuning) no more maps
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
04-30-2011, 09:43 AM | #6 |
51
Rep 923
Download the 3-30 DIC firmware, and upload it to the Procede. Follow the directions in the Read ME file for uploading and resetting adaptations. With your mods and 94 octane you should be safe running 14 psi. Since there is no autotuning, you'll have to go to the User Adjustable Parameters and set your Start Boost at 40. If you are worried about it, you can leave it at the default setting which is 13.5 psi. If you wanted to confirm your car is running fine on 14 psi you'll have to datalog and look at your timing curve to make sure the car isn't pulling timing.
04-30-2011, 09:46 AM | #7 | |
184
Rep 2,320
04-30-2011, 09:59 AM | #8 | |
51
Rep 923
04-30-2011, 10:03 AM | #9 |
184
Rep 2,320
everything solved sorry for OT
04-30-2011, 10:21 AM | #10 |
51
Rep 923
PM sent...sorry OP for the off topic conversation
05-02-2011, 08:15 PM | #11 |
"J" BONE
24
Rep 578
i do run the pro version...i got it all set up and am running at 40% boost. so now i just have to figure out the data logging and figure out what it all means
