The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > 07 e92 Coding Error
      04-28-2011, 03:35 PM   #1
antiks
antiks's Avatar
41
Drives: E90 Alpine White
2008 335i  [9.00]
07 e92 Coding Error
So we ran into an error while coding an 07 e92 w/ cobb installed; did the digital speedometer stuff in the Kombi; and got a "speedometer malfunction" error; it's still there even after coding the module back w/ the blank man file; and even after un-marrying the cobb to the car; the error still is there; none of the gauges work now; ie tach/speed/fuel/temp/etc.. all the analog ones; anyone run into this error before?
IG: realantiks
      04-28-2011, 04:14 PM   #2
Motastic
Motastic's Avatar
84
Drives: E92 335!
Well on this specific car, a birdie told me the only thing that works is the speedometer lol
So anyone got any ideas...help a brotha out.
The gauges all kick in for a good 30 seconds and than the tach / temp / gas gauges all fall and iDrive says "speedometer display malfunction"
      04-28-2011, 04:27 PM   #3
Motastic
Motastic's Avatar
84
Drives: E92 335!
Hey Antiks
I was reading on another forum and people have encountered the same error, they did the following
Alright. I tried with a semi-maybe updated rar of NCSExpert, flashed blank kombi, this time it worked. Speedometer warning is gone and my cluster (rpm, fuel gauge) works again. Although I don't think I have the latest ncs because it can't read the CIC. I'll see if I can find an updated one in the search later.
also
I got this same error after trying to code the m3 speedo on my 2008 e93, turns out I didn't properly read the kombi, so had the trc file from the whole car and then modified and wrote back, received error, rewrote with blank man file and then figured out my issue and did it right the second time. Usually if I have out of date daten files, I can't even read the modules.
wanna give one more shot tonight? i really do not want to take it to he stealership
      04-28-2011, 04:45 PM   #4
Motastic
Motastic's Avatar
84
Drives: E92 335!
it also says
You need latest daten files. Great to hear all fixed.
basically everyone said that you have to update the "daten" files which will fix the error
      04-28-2011, 05:06 PM   #5
antiks
antiks's Avatar
41
2008 335i  [9.00]
k updated the daten stuff; gonna go start er up on the car and check for errors
IG: realantiks
      04-28-2011, 06:00 PM   #6
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
No_Country
36
Drives: 2010 Toyota FJ
Update? Hope it worked out for you. New daten and a blank flash should do ya.
      04-28-2011, 07:25 PM   #7
antiks
antiks's Avatar
41
2008 335i  [9.00]
yup that worked; however the new daten files won't read the nfrm anymore..lol..strange i know..but we coded all that w the old daten files
IG: realantiks
      04-30-2011, 01:28 AM   #8
Motastic
Motastic's Avatar
84
Drives: E92 335!
so now we will try to do that next week sometime lol
      04-30-2011, 02:20 PM   #9
CasperSYTFU
SYTFU Crew
No_Country
36
I've actually tried to update daten and got a Faulty Chassis error and reverted back to my previous files.
Did you run into that error and fix it?
      04-30-2011, 05:49 PM   #10
X2Board
X2Board's Avatar
444
Drives: I'm back, bitches! '13 E92 ZCP
I've coded my car with COBB installed and never had a problem. What version of NCS Expert/Daten files are you using?
      05-03-2011, 11:32 PM   #11
jyono
Drives: 2006 330i Sedan
Same Problem
Antiks,
I am facing the same problem with my analog gauges after coding the Kombi Module.
Now after updating daten files with either ista v34 or v40 I always get the "chassis faulty" error in ncsexpert.
Could you share with us which version daten files that you used and the process followed for updating them without errors? Thanks.
My Current Setup:
1. 2006 e90 (330i) - Had programming done at the dealership in mid April '11
2. Ediabas version: 6.4.7
2. NCSexpert version: 3.1.0
      05-04-2011, 09:43 PM   #12
jyono
Talking
Update:
Solved my issue using ISTA v41 Daten Files.
1. Copied and pasted new daten files to [ C:\NCSEXPER\DATEN\E89 ] and ran laden.bat
2. Copied and pasted new sgdat files to [ C:\NCSEXPER\SGDAT ]
3. Copied and pasted new ecu files to [ C:\EDIABAS\Ecu ]
This time NCSexpert worked fine, no "Faulty Chassis" message!
Re-coded with a blank .MAN file and functionality my the analog gauges (rpm/mpg/fuel) were restored!
      05-05-2011, 06:20 PM   #13
antiks
antiks's Avatar
41
2008 335i  [9.00]
Originally Posted by jyono View Post
Update:
this is what i did also
IG: realantiks
      05-06-2011, 10:38 AM   #14
Motastic
Motastic's Avatar
84
Drives: E92 335!
antiks ready for another go sometime soon?
      05-06-2011, 02:53 PM   #15
CasperSYTFU
SYTFU Crew
No_Country
36
great news! i'm updating to v41 today and seeing if my faulty chassis message goes away.
      06-22-2011, 06:38 PM   #16
S1000RR
12
Drives: ZCP M3
Same thing happened to me. Where can I get the new Daten files?
      06-24-2011, 09:23 AM   #17
justa3series
Drives: 2010 328xi
Search other forum or google for ISTA V41 for latest daten available or ask member to send you E89 files. It's under 50mb.
      06-27-2011, 08:11 PM   #18
xxxjecxxx
xxxjecxxx's Avatar
247
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
This guide was originally posted by FAL, I just redid the images and created the entry in this wiki!
To update your system properly it is highly recommented that you use the tool Total Commander. There is a 30 days trial available.
If you copy the files manually - without Total commander - you might overwrite newer files with old ones. That's the difference between updating and doing it properly...
What you need checklist:
Total Commander
v40/v41/newer/older ISTA/P files, includes
daten - folder
ecu - folder
sgdat - folder
common sense and basic knowledge in computers
Difficulty: easy
Make a copy of your EDIABAS, EC-APPS and NCSEXPER folders. It's always good to keep some backups...
Start Total Commander
In the left window of Total Commander, head for your new daten-folder. In the right window, move to C:\NCSEXPER\DATEN\E89 (or another model you want to update). Now your screen should look like this:
Click on 'Mark' > 'Mark newer, hide same files'
As you can see on the following pictures, the newer files on the left will turn red. Drag one of these red files to the right windows and drop it there.
A windows will come up, just confirm it with 'OK'
Another window will pop up, now comes the clue: Here, select 'Overwrite all older'. All newer files will now replace the old ones, while equal versions or even newer files stay untouched.
Bibidi, babidi, boo - else updating is poo
Repeat this with the following folders:
C:\EDIABAS\ECU
C:\NCSEXPER\SGDAT
I did not write this but this is what you need to follow. If you copy over every single file you WILL run into issues.
      09-03-2011, 09:42 PM   #19
BRAISKI
BRAISKI's Avatar
135
Drives: '11 335xi e92 M-Pak
2011 BMW 335xi  [7.00]
Update:
When you recode with a blank .MAN did you use the "FSW PSW TRC"?
      09-04-2011, 06:26 AM   #20
._.
74
Drives: BMW
Use expertmode.
      09-06-2011, 07:52 PM   #21
BRAISKI
BRAISKI's Avatar
135
Originally Posted by r45t4m4n View Post
Use expertmode.
Finally got the stuff back!
      09-06-2011, 08:53 PM   #22
antiks
antiks's Avatar
41
2008 335i  [9.00]
lol..scary at first wasn't it?
IG: realantiks
