What type of AMP Should I use?
04-25-2011, 04:22 PM | #1 |
Rep 46
I want to add one 12" kicker subwoofer to my Logic 7 factory system. I was gona use kicker amps but they have 300-500 watts. Im not sure how much do i need to run a 12' sub without troubles. Any idea??
04-27-2011, 01:57 PM | #2 |
Rep 194
Depends on a few things really. What type of 12' sub (what model) and specs? also a mono block 300-500 watt RMS rated amp will absolutely give you more than you need as far as bass on a stock internal stereo system.
04-27-2011, 08:42 PM | #3 |
21
Rep 176
300-500 RMS on a single 12" speaker will make your mirrors useless at anything higher than low volume. If you're not upgrading the entire system then 200 RMS will probably be more than enough.
04-27-2011, 08:52 PM | #4 | |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
in that case i'd recommend a 2 channel amp 2x200 so he can try with one channel if he;s happy leave it at that if he feels its too low he can bridge both channels and give it 400w |
04-28-2011, 10:20 AM | #6 |
21
Rep 176
04-28-2011, 10:54 AM | #7 |
Rep 46
