noob question about down pipes and o2 sim
04-20-2011, 03:33 PM | #1 |
127
Rep 571
i am buying the raceland DP's and i heard that you need o2 sims. i thought the raceland dp had o2 bungs in them so why do you need the o2 sims
can some one explain this to me and show me where i can get them if i do need them |
04-20-2011, 04:19 PM | #2 |
124
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
these catless pipes?
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
04-20-2011, 05:07 PM | #6 |
70
Rep 2,626
You still need your oxygen sensors and thats why you get O2 bungs on all downpipes. The O2 simulator is needed to trick the ECU by making it read data from the sensors close to that you would read when the cats are there... it does not replace the sensors, you always need to sense the exhaust gases or your car will operate correctly...
SO yes you need both unless you want to see a service engine soon on your dashboard.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-21-2011, 02:00 AM | #7 |
Welcome to the Thunderdome!
13
Rep 141
BMS o2 simulator "Down Pipe Fix", about 80 bucks...plugs into your ecu 19,20,23 pins.....you can also plug it directly into you jb4 or vishnu harness....if you got one
2008 e90 335i, Vishnu V5, DCI, PWM METH, AMS FMIC, AR catless, BMS o2 sim, and HKS exhaust.
Last edited by Maddawg58; 04-21-2011 at 02:01 AM.. Reason: cause I don't know how to spell |
04-21-2011, 08:33 AM | #8 |
18
Rep 368
Correct me if I'm wrong but JB4 doesn't need an O2 Simulator. It comes with a built in Downpipe Fix, doesn't it?
04-21-2011, 09:59 AM | #9 |
70
Rep 2,626
Yes it does
04-21-2011, 12:26 PM | #10 |
13
Rep 141
Yeah, just check it and I guess it does.....vishnu prior to v5 harness update had an o2 modifier built into pins 19,20. The BMS has an additional feature, haven't quite figured out what that is.......whatever it is, it smoothed out my car after downpipe install.....I was the guy with oscillations......prob o2 sensor on the way out
04-21-2011, 03:54 PM | #11 |
Rep 101
You can use a spacer to pull the sensor slightly out of the exhaust stream, this will generally fix the CEL. You also want the bungs in the proper places so the sensors dont hang down and you wont need to tie them up. The bungs can also be used for live tuning.
08-06-2011, 11:10 AM | #13 |
172
Rep 698
Drives: you crazy..
Garage List 2019 BMW M2 Competi ... [0.00]
(SOLD) 2016 BMW M235i [10.00] (SOLD) 2015 BMW M4 [10.00] (SOLD) 2008 e93 M3 [10.00] (SOLD) 2007 e92 335i [6.50] (SOLD) 2003 e46 325i [10.00] |
Sorry for resurrecting this post.
So, is there any re-wiring needed to enable the DP fix for JB4s? Or if you have JB4 installed just install the DP and you're done? THanks
Punky 2021 Model Y Long Range Performance 2018 F80 M3 CS [Sold] 2019 F87 M2 Competition [Sold] 2016 235i ?M? [Sold] 2015 F82 M4 [Sold] 2013 C350 [Sold] 2008 CRV [Sold] 2008 E93 M3 [Sold] 2006 E92 335i [Sold] 2002 325i [Sold] 1996 318i |
08-06-2011, 12:46 PM | #14 |
ElevenPointFive
326
Rep 2,450
Just set auto code clear function on for JB4 or Procede and that is your DP fix. No wiring or other BS needed.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
08-06-2011, 12:50 PM | #15 |
187
Rep 1,103
08-06-2011, 02:47 PM | #16 |
ElevenPointFive
326
Rep 2,450
Nowhere did the OP state anything about an emission test but you are indeed correct. Those that are concerned about emissions tests should re-installed the stockers to pass such tests.
08-06-2011, 02:53 PM | #17 | |
11
Rep 529
Map 0 + no codes + readiness set + CanClear off = PASS (That is for states that inspect by OBDII.) |
