Vishnu Procede n55 dyno with prototype FMIC (360+WHP)
04-18-2011, 04:36 PM | #1 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
Been a busy last few weeks. Today we tested the prototype FMIC we've developed for the n55. Tried a couple a couple different FMIC designs before settling on this one. It works the way we want it to and seems to be perfectly matched to the stock turbo. Better cooling but without excessive volume (no extra lag). And not excessively heavy (less of a heat sink). We plan to go into production with it after we get caught up with other things. No ETA yet. No pics to disclose. But the results were very promising. The Procede map was a slightly tweaked version of the 3-21 maps that are currently available for download. Tweaks involved small changes to the IAT compensations and ignition timing maps. Car info: N55 135 w/7DTC 91oct Vishnu Procede v5 Vishnu DP Vishnu Large charge pipe Cat-back Stock FMIC vs. Vishnu Proto FMIC: Same dyno with nearly identical conditions Boost setting at 15psi, IC at 50% Below is a video of a 15psi run. You can watch the boost gauge on the dash (fuel gauge) during the run. It peaks just shy of 15psi in the midrange and falls to 10-11psi up top. Pretty low boost for 360+whp. The n55 is an excellent engine. Better than the n54 in many respects i'd say. And a properly matched FMIC upgrade was worth 20-30whp gains from 4200 to 6500rpm! We also did a few runs at a lower peak boost setting (just 12psi). Lost quite a bit of low end/midrange torque. But only down 6-7hp peak. In fact, it made slightly more power way up top no doubt because IATs were slightly lower (from running less boost down low). 15psi peak vs. 12psi peak: Last edited by OpenFlash; 04-18-2011 at 04:44 PM.. |
04-18-2011, 05:29 PM | #3 |
Formerly (-(ellblazer420
48
Rep 703
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Torque monster!!!! Good stuff Shiv
04-18-2011, 05:52 PM | #4 |
86
Rep 1,262
What is all this not working on the fuel system/meth kit nonsense?
Get back to the real work Nice numbers though, and holy fan setup! that beats the asthmatic wimpy thing I had when I dyno'd!
Josh-
04-18-2011, 06:06 PM | #5 |
654
Rep 8,801
those numbers look very good at 15psi.
have u taken'n it to the track with that setup? i'm happy with the boost setting at 12psi - numbers look great with the FMIC - shoot, but if settings at 15psi are consistent on the track - i'm jezzing. i'm dye'n over here waiting on a couple of tunes. i have a fmic just sitting here ready to be slap'd on. oh well, whenever you guys are ready.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
04-18-2011, 06:12 PM | #6 |
12
Rep 132
Shiv I'm curious, the last Dyno you posted under the 15 PSI pulls you had something like 425 TQ, why did it drop after upgrading the charge pipe and FMIC although granted your HP numbers went up a bit?
04-18-2011, 06:16 PM | #8 | |
1736
Rep 17,960
Drives: A Lot
Shiv |
04-18-2011, 07:08 PM | #12 |
35
Rep 553
I will be happy to test the new maps since i have fmic
Need a testmule?
USED TO HAVE A 385 whp 479 tq N55 335 2011 (AT) AND NOW A 135 M package 2010 (AT) 447whp/504tq
04-18-2011, 07:49 PM | #13 |
173
Rep 1,343
Drives: BMW M3 DCT
HELLA NICE!!!
04-18-2011, 09:40 PM | #14 |
92
Rep 1,465
Shiv, no thoughts on making a FMIC or DP's for the N54? I know Rob said the market is "flooded" but I know if you designed something people would buy it based because of your reputation rather then people making something simply for $$$$.
11 E92 M3 DCT Jerez Black ZCP...Eisenmann, Dinan, Fabspeed, IND, LUX
04-19-2011, 01:36 PM | #22 |
1736
Rep 17,960
Drives: A Lot
Yes that's where the n55 seems to have a sizeable advantage. Power power at a lower boost pressure all things equal. Suggests that the head flows better (less boost accumulated at the manifold). There is also far less pumping loss during non-WOT conditions (no manifold vacuum) which means smoother engine performance. And you can feel it. Especially during transitions from partial to full load. I can't wait to see what this engine will do with an upgraded single turbo. Wouldn't be surprised if it made 450whp at just 15psi from GT30R or something comparable.
Tags |
best intercooler, best tune, procede |
