Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Error trying to code module KOMBI (IFH-0003: Datatransmission to interface disturbed)
      04-13-2011, 09:09 PM   #1
shag
pullin a boat
shag's Avatar
37
Drives: 2021 X3 M40i
Hello,
I have a 2009 328i xDrive and have been trying to code BC_DIGITAL_V and some other features in module KOMBI. I can read the KOMBI module without issue, but anytime I try to do "Basic Functions->coapiReadSgGetFswPsw" it gives me the following error after the dialog box:
COAPI-2000: EDIABAS or SGBD error
IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED
Any ideas? This is my first time coding this car.
2021 X3 M40i, Phytonic/Cognac
Past:
2017 330i xDrive Touring M Sport, EBII, Dinan
2014 328d xDrive Touring M Sport, BSM/CR.
      04-15-2011, 12:58 PM   #2
HomeBrew
43
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
2006 BMW 330i  [0.00]
similiar issue
I get this when walking through the DIY and attempting to read from the airbag module:
From the INPA FAQ (the code and message do not line up, but the doc is attached - page 4,5):
1.4 IFH-0003: Data transmission HOST/Interface failed
  • Reason 1: In the Ediabas.ini file, the interface is set to STD:OBD. However, you have connected an ADS connector.
  • Solution 1: Modify the interface setting.
  • Reason 2: The data transmission failed when sending (e.g. short circuit in the line).
  • Solution 2: Get rid of the short circuit, for example.
  • Reason 3: Connector not connected or no power supplied.
  • Solution 3: Check whether the connector is connected and is supplied with power.
  • Reason 4: The device manager has been used to disable the FIFO buffer for COM1.
  • Solution 4: In the device manager (Windows XP: Enter “Start” ␣ “Control Panel” ␣ “System” ␣ “Hardware” ␣ “Device Manager” ␣ Ports (COM & LPT)), and then select COM1 from the ports. Then under the “Port Settings” tab, select “Advanced”. There must be a check-mark by “Use FIFO buffers” and “8” must be selected for the receive buffer and transmit puffer.
1.5 IFH-0010: Data transmission to control unit disturbed
  • Reason: With Windows XP, it is not possible to automatically set the receive and transmit buffers using OBDSetup.exe, like in Windows NT.
  • Solution: Set the receive and transmit buffers to 8 as shown in the following: Use Start ␣ My Computer ␣ Control Panel␣ System ␣ Hardware ␣ Device Manager ␣ Ports (COM & LPT) and then click with the right mouse button to call up the properties of the COM port that is being used. Under the Port Settings tab, set the Data bits of the receive and transmit buffers to 8.
Of course with Windows 7 (vista, etc) will need the serial registry values updated to match these.
I was about to post my own topic on my issue (reading and getting the same error). I haven't been able to figure it out, hope this helps.
EDIT:: After that post, I found the resolution to my issue, drivers. I uninstalled the devices and drivers under the windows device manager and rather than installing the drivers which came with the software (cause of the my problem). I configured windows to search windows update for appropriate drivers and now everything works.
Good luck.
2017 BMW M3 - Tanzanite Blue with Full Silverstone Interior
      04-15-2011, 04:23 PM   #3
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Ignition on?
      04-17-2011, 10:24 AM   #4
shag
pullin a boat
shag's Avatar
37
Well, I have a USB cable so those FIFO parameters are non-existent. I've determined that I can read/code the car but I need to try it 15-20 times before it goes. I think I might have a COM port conflict
Past:
      04-17-2011, 10:55 AM   #5
fdriller9
252
Drives: '06 AW 330xi
2006 330xi  [6.44]
Try keeping your hazards on
It prevents the module from going to sleep.
      04-17-2011, 12:04 PM   #6
HomeBrew
43
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
The FIFO params do exist, but only in the registry:
HEKY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\servic es\Serial
RxFIFO
TxFIFO
Both should be a DWORD, 32-bit, hexadecimal, and set to 8: 0x00000008
      05-26-2011, 07:56 PM   #7
E90aL
15
Drives: n52
did anyone find a solution to this problem? I used to be able to code, but I have been getting this error every time. I also get FA-Fehler sometimes.
      05-27-2011, 09:58 AM   #8
orangedawg
31
Drives: 328xi
Not sure if this will work for you, but I got that error when I was running just off the battery. Hooked up a battery tender and all was good. So, maybe that will work for you? If not, I don't know what else to try.
      05-28-2011, 12:15 AM   #9
E90aL
15
Drives: n52
didn't work. what message do you get when you run ncs with the cable plugged into the computer only?
      05-28-2011, 10:20 AM   #10
orangedawg
31
Drives: 328xi
I get the same message you get with cable plugged into computer, using fsw psw profile, do the f1, f3 thing, then get the exact error message comes up that you have. So, it's not reading your car somehow.
      05-28-2011, 12:08 PM   #11
Elliott@DetailAddict
300
Drives: E90
Double check your latency is set to 1 and not 16 in the com port advanced options.
      05-28-2011, 01:27 PM   #12
E90aL
15
Drives: n52
My latency is set to 1, the two things above it are set to 4096. FIFO values are set according to the NCS DIY. It's set to COM1.
      05-29-2011, 01:03 PM   #13
BMW4Life2112
BMW4Life2112's Avatar
14
Drives: E90
If your latency settings are set to 1 then maybe you can try this...
Make sure that after you read the KOMBI that you go to the "work" folder and open the FSW_PSW (TRC File). Then, as DIY say's click File > "save as" FSW_PSW.MAN and set to read "all files" instead of "text". Then open your FSW_PSW (MAN file) and make your changes to the KOMBI. Then try doing the "Basic Functions > coapiReadSgGetFswPsw" and see what happens.
Sometimes when I go too quickly and forget this step, I get the same error message you get.
      05-29-2011, 01:17 PM   #14
300
Drives: E90
LOL yea like when you never save the TRC to a MAN and then code
      05-29-2011, 03:17 PM   #15
BMW4Life2112
14
Drives: E90
Haha Grant, I know what you mean! Sometimes I open the .trc file and make my coding changes there! Although, I usually catch my mistake before I go to save it as a .man file.
      05-30-2011, 12:11 AM   #16
E90aL
15
Drives: n52
the problem is I can't get the computer to read the FA anymore. i get the error after these steps: connect car>turn ignition on/engine off>load FSW PSW MAN>F1>F3>E89
      05-30-2011, 11:47 PM   #17
BMW4Life2112
14
Drives: E90
Hey E90al,
A few things you can try:
1.) Plug cable into car, turn ignition on, and run INPA. Make sure both dots are black. If you do not have both black dots then close INPA and try running program again. If you do have both dots black, close INPA (but leave Ediabas server on). Don't proceed with the next step until functionality between your computer, cable, and car are established.
2.) Make sure you are running NCSEXPERTool as an administrator on Windows. To do this you can right click on the NCSEXPER icon on desktop and click "run as administrator".
3.) Update your daten files. You can do this a couple of ways, the easiest is to go to NCSEXPER folder (should be located in c > Daten > E89 > Double click and run "LADEN" file, this should update yor daten files automatically. Another way to do this is to copy and paste new daten files that you can get off the internet. Tr searching for them, or I can help point you in the right direction.
3.) Make sure you are using the correct drivers for your OBD ebay cable. The drivers for the ebay cable are located here (http://www.ftdichip.com/Drivers/D2XX.htm)
      06-02-2011, 06:53 PM   #18
E90aL
15
Drives: n52
Hey E90al,
4.) Make sure you are using the correct drivers for your OBD ebay cable. The drivers for the ebay cable are located here (http://www.ftdichip.com/Drivers/D2XX.htm)
1. The dots are black but when i try to read something it has the data transmission error. This didn't happen 3 months ago.
3. When you update where do you put the downloaded files?
4. When I use the drivers from the website, I get a BSOD that has something to do with ftdi.sys(something like that). The only way to avoid bsod is using the drivers in the Ediabas\hardware\obd\winxp\usb2.0 folder.
If it is a faulty cable, i would like to return it asap because warranty for it is almost over.
      06-10-2011, 02:31 PM   #19
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
Hi,
I'm getting the same error with a 2008 E92 M3. Does anybody know what might be causing this?
I know for sure that it's not the cable since it works perfectly with my 2006 E92 335i.
      06-10-2011, 03:59 PM   #20
fdriller9
252
2006 330xi  [6.44]
Originally Posted by cedchung View Post
Hi,
2006 and 2008 use different interfaces....one is K can the other D can.
      06-10-2011, 05:31 PM   #21
cedchung
Mauritius
64
After some research, I found out that I have to remove Pin 8 for it to work on 2008+ cars
      06-13-2011, 09:28 AM   #22
cedchung
Mauritius
64
Update: It worked with Pin 8 removed
