FS: 2 Michelin PS2 265/35/19
04-08-2011, 10:19 AM | #1 |
231
Rep 3,561
I've got 2 Michelin PS2s in 265/35/19 size. They've got about 6-7/32 tread, good for a summer or two (depending on how/what you drive ) The catch is, one is the standard 94Y load rating, while the second is 98Y load rating. From what I could find, they can be used together without any issues, though I'm no expert, please post if you know otherwise. I'm selling as I'm parting the whole car, I would have had these mounted otherwise. Load Ratings are 94Y = 1477lbs and 98Y = 1653lbs (support per tire). These are the only 2 load ratings available for these size tires (on tirerack at least). Speed ratings are the same for both at Y = 186+ mph. Edit (4/20): I just called tirerack (1 888 353 5082) and asked about mixing the 2 different load ratings (gave specific car/tire info). I was told that mixing load ratings is OK, so long as the speed ratings are the same (which they are in this case). One (98Y) has a small plug about the size of a dime on the inside, pictured below. Price is SOLDSOLDSOLD. Last edited by yakev724; 04-28-2011 at 12:00 AM.. |
