2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Xdrive wheels on a non xdrive car?
      04-07-2011, 10:34 AM   #1
Khurram
Khurram's Avatar
49
Drives: 2012 Panamera 4
Ok guys this may be a stupid question but here we go:
I purchased a set of oem 331 wheels which came off a 535i with x drive.
My car is a 535i base with no x drive.
I want to mount these wheels with hankook ventus v12 245/40/19 in the front and 275/35/19 in the rear.
Will this setup work or will there be any fitment issues?
Thanks
      04-07-2011, 10:48 AM   #2
dr.mba
dr.mba's Avatar
275
Drives: 2017 F. Grey M3 ZCP
Don't qoute me on this one but I think the x drives have 19x8.5 all round while the rwd cars have those in the front and 9" in the back. Do you happen to know the width of the wheels you have??
      04-07-2011, 11:06 AM   #3
Khurram
Khurram's Avatar
49
Yes you are correct that the x drives have the same width wheel all the way around. Will this cause a problem with the setup I am aiming for?
      04-07-2011, 11:06 AM   #4
Khurram
Khurram's Avatar
49
I haven't checked the width of the wheels but I do know they came off an xdrive
      04-07-2011, 11:19 AM   #5
dr.mba
dr.mba's Avatar
275
If you have 8.5" width in the back you're not going to be able to mount 275 in the back because the tires would be too wide for that rim. You can check out 1010tires.com tire calculator to see what the widest tire you can mount on a 8.5" wheel. I think you maybe able to slip in 265s but that maybe stretchg it and your run the risk of the installer damaging the lips. Just my 2 cents.
      04-07-2011, 11:22 AM   #6
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
If they're 19x8.5 all around, as I believe they are on the xDrive, I wouldn't do 275/35/19 in the rear.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      04-07-2011, 11:29 AM   #7
Khurram
Khurram's Avatar
49
Assuming the wheels are the same width all the way around- what would you guys recommend for front and rear tire sizes considering my car is non x drive?
      04-07-2011, 11:33 AM   #8
Khurram
Khurram's Avatar
49
And what profile size as well? Would 40 work?
      04-07-2011, 12:19 PM   #9
dr.mba
dr.mba's Avatar
275
I would keep the same configuration as the x drive and have 245s all round. That's my opinion as I dont see the point of stretching tires and 255 wouldn't be that much different than 245 bearing in mind what I said about going to 265. I would get 40 profile.
      04-07-2011, 12:29 PM   #10
Khurram
Khurram's Avatar
49
So no point in doing 255/40 rear and 245/40 front?
I know it's not much of a stagger but isn't a little bit better than nothing with a rwd car? Price is the same.
I guess I loose out on rotating but then again BMW says not to rotate anyways.
5post
