2010 2011 BMW 5 Series Forum F10 Question regarding audio |
04-05-2011, 11:44 PM | #1 |
Rep 37
Hey guys, I need some help with the audio system.
1) What's the aux input inside the glove box for? I connected my ipod to that and it doesn't seem to work that way. 2) Is it possible to save songs from a USB memory stick to the car's music hard drive? I know how to save music from a CD, but don't know if it works with a USB memory stick or ipod? Thanks! |
04-06-2011, 01:19 AM | #2 |
138
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
1. Make sure to select the "aux input" on the stereo. And there's a volume gain control for that connection. Make sure it's turned up. You should be using the aux input port in the center armrest. I don't know what the one in the glovebox is.
2. You can play music over USB from a flash drive or iPod only if you have the USB in the center console armrest (6FL/6NR option code). The USB port in the glovebox does not allow for that function. |
04-06-2011, 01:19 AM | #3 | |
14
Rep 231
2. Yes, plug a USB stick into either glove box/armrest and go to external devices and import. only armrest USB supports play from USB stick. Ipod will not work with glove box USB. |
04-06-2011, 04:11 AM | #4 |
21
Rep 306
Elsewhere on this forum others have written that they have USB hard disk drives plugged into the glove box and it works well.
Different drives require different power levels so a careful selection would be required if purchasing. |
04-06-2011, 09:11 AM | #5 |
Rep 76
Is anyone streaming Pandora music through their plugged in iPhone?
If you are streaming Pandora music: 1) Which input(s) are you plugged into? 2) Does the Pandora screen display on the BMW screen? 3) Are you able to use the iDrive to control, select, skip songs ? 4) Which iphone models can do this? Thanks |
04-08-2011, 09:19 AM | #7 | |
Rep 59
I just tried this for the first time yesterday.
Pandora works with my plugged in iphone4 (connected to the aux input) or via bluetooth. 1. aux input 2. No 3. I did not look to try this this. I do not think it's possible 4. Iphone4 Quote:
04-09-2011, 11:19 AM | #10 |
Rep 76
mrcamp - I should have asked this earlier:
Have you tried connecting your iPhone to the USB connector in the center console using the white apple cable, instead of connecting through the Aux in the center console? With any ipod or iphone, the music lists, selections etc all appear on the BMW idrive screen. Will this enable you to also view the streaming Pandora music info on the idrive screen? Also, what is the build date for your F10? Before or after 9/1/10 .... 3/1/11? Thanks again. |
04-09-2011, 01:37 PM | #11 | |
Rep 59
For the Ipod functionality on the phone, Yes. I have connected it to the USB connector. Playlists, artists, album art etc. shows up on the Idrive screen.
As for playing pandora while connected via USB, I believe I tried and it did not work. I will have to try it again. Quote:
04-17-2011, 12:06 AM | #12 | |
registered
Rep 87
Drives: 535i titanium silvr 1/11 build
I don't have a usb port in the glovebox of my new F10. The console usb supports an iPod Classic through the Apple furnished sync cord but does not support an iPod Nano Gen 2. |
