Right Rear light Bulb is Burned ! And How do I get it To Work?
04-05-2011, 06:28 PM | #1 |
138
Rep 621
My right rear parking light is out and I tried to change the bulb but that doesn't work as well. I'm thinking that it has something to do with the bulb carrier? This is for an e92 07 and it's out of warranty? Should I go to the dealer or is this something I can do myself?
It's # 4 in the diagram. |
04-05-2011, 06:53 PM | #2 |
87
Rep 1,032
Drives: 2006 330i & 2010 535i
I had the same problem
My wife had a 2004 325i and her rear light went out. I thought it was a simple fix by replacing the bulb with a new one, but it wasn't. I took the car to my mechanic who repaired it. I forgot exactly what he did because we sold the car, but he said it's a common problem and he had to rewire the wires. Try Googling it.
2006 330i Jet Black w/ Beige Leather/Sport/Prem/Step/Shades/Xenon/Logic 7 |
04-05-2011, 07:01 PM | #3 |
169
Rep 12,680
Drives: like an asshole
Go to the trunk and take out the piece of liner on the side you want to work on. Should just have to twist the black dial and it loosens it. When u get to the brake assembly u squeeze the gray piece (I believe) it pops out a larger assembly and just pluck the bulb out. It's all easy and shouldnt have to use lots of power
04-05-2011, 07:05 PM | #4 | |
138
Rep 621
04-05-2011, 07:13 PM | #5 | |
697
Rep 2,079
04-05-2011, 07:29 PM | #6 |
169
Rep 12,680
Squirrel master won't be around next time
04-05-2011, 11:11 PM | #7 |
Registered Bro
18
Rep 197
Funny, my 07 just started giving me "right rear brake lamp out" warnings on the dash, but I looked at the rear of the car and the bulbs look fine. The warning only comes on sometimes, every 5 or 6 starts it'll pop up.
04-06-2011, 04:04 AM | #9 |
11
Rep 237
probably corrosion on the harness connectors
E92 6MT Saphire Blk l Blk Dakota l Grey Poplar l Premium l Sports l Comfort Access l Cold Weather l Nav+Idrive l Bluetooth l I-Pod & USB l PDC l Logic 7 l
City Car: 2005 Saab 9-3 TiD Retired: E60 530i |
04-06-2011, 04:52 AM | #10 |
1706
Rep 14,829
Mine went out when the car was less that 6 mos. old. The dealership told me it wasn't just the bulb, it was the carrier. Only on a German car, right? I've seen new E92's with one side of the front lights out.
04-06-2011, 11:23 AM | #11 |
169
Rep 12,680
yea i had 500 miles on it whe they replaced the whole rear light assembly for the recall. no problems thus far
04-06-2011, 11:38 AM | #12 |
224
Rep 699
Have the same bulb i think, on the same side out now. But for me its the braking bulb, and last time i checked you have to brake to light it up so put some weight on the brake pedal or have someone brake for you and see if it lights up. Also check the error codes.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
04-06-2011, 11:52 AM | #13 |
20
Rep 244
is the bulb definitely out or are you just getting the warning on the dash? i used to get that warning every couple months but the bulb was never really out
04-06-2011, 02:39 PM | #14 |
138
Rep 621
what does tsb stand for? But yeah, I have been researching and it does seem like it's a common problem with the bulb carrier.... However, I switched the whole bulb carrier from the non-working right to the working left wire harness and it worked! So I don't think it's necessarily the carrier itself, but more so something with the electrical harness.
04-06-2011, 02:40 PM | #15 |
138
Rep 621
When I brake the bulb lights up like normal, however when I turn on the headlights, that particular bulb should stay on, but it does not.
04-07-2011, 03:13 AM | #16 | |
Titanium silver + Sport + Premium
32
Rep 662
04-07-2011, 03:30 AM | #17 |
32
Rep 662
SI B 63 02 08
Lights March 2008 Technical Service SUBJECT Rear Bulb Failure MODEL E92 (3 Series Coupe) vehicles produced up to January 21, 2008 SITUATION The "bulb out" warning shows in the instrument cluster. Diagnosis shows a fault for the rear lamp. CAUSE Poor fit between the bulb and bulb holder CORRECTION In the case of a customer complaint, replace the complete bulb holder housing. Refer to Repair Instruction 63 21 055 (Replacing a socket housing for left or right rear light [side panel]). The replacement part is supplied complete with bulbs. PARTS INFORMATION Part Number Description Quantity 63 21 4 428 113 Bulb holder with bulbs (Left) 1 or 63 21 4 428 114 Bulb holder with bulbs (Right) 1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code 63 21 00 79 00 Main Work* Labor Operation: 63 21 055 Replacing one bulb holder housing Labor Allowance: Refer to KSD *Main Work: Use this labor operation number when this is the only repair being performed, or if this is the main repair when performed along with other repairs at the same time. If this is not the main repair, refer to KSD for the associated (+) labor operation code. |
05-02-2011, 08:30 AM | #18 | |
Rep 28
Do you know the bulb holder's P/N for the dome light? Car is 320i LCI E90. Thanks in advance with the help. Cheers. |
05-02-2011, 05:47 PM | #19 | |
32
Rep 662
05-02-2011, 05:52 PM | #20 | |
1706
Rep 14,829
05-03-2011, 04:02 AM | #21 | |
32
Rep 662
05-03-2011, 04:36 AM | #22 |
1706
Rep 14,829
All kidding aside, it does look like the part is $19. But does recoding need to take place? It reminds me of a 200 series Volvo I once had. If a lamp went out, it was not the lamp nor socket, it was the printed circuit, and it cost I think $70, and they'd have to be replaced over and over. It made me wonder why Europeans make things overly complicated....
p.s. what provides light to the light bars running through the assy? |
