fs:K+DCAN Cable for Coding
04-05-2011, 05:29 PM | #1 |
59
Rep 1,411
One K+DCAN Cable for Coding...
lmk whether you have the 09+ model car or Pre-09... if it's pre-09 i would solder the pin 7-8 for you if not i'll disconnect the soldering between pin 7-8 asking price : $85 Shipped Andre |
04-05-2011, 05:43 PM | #2 |
252
Rep 7,089
Drives: '06 AW 330xi
Interested but why do you need to solder anything?
I thought 06s just needed Kcan and post 06 needs Dcan. |
04-05-2011, 05:53 PM | #3 | |
555
Rep 1,244
Drives: 2013 F10 M5
07-09 D-CAN cars don't use pin 8 but still does use pin 7 so the cable continues to work fine, but in 09-10 BMW re-used the pin 8 position for ethernet, so if you have an interface that has pin 7-8 connected (and most of the ones you find on eBay and such do), you'll get errors trying to communicate with the car because of the ethernet connection at pin 8 interfering with the D-CAN connection on pin 7. This is one reason I'm planning to get a J2435-1 compliant cable and try it out (to be used in the times I don't want to break out the big orange OPS head). EDIABAS supports J2435-1 passthru and a compliant cable, like a Tactrix OpenPort 2.0 cable should work on any model without modification. And it should work with ISTA online at www.bmwtechinfo.com for diagnostics and programming. Last edited by Dracon; 04-05-2011 at 06:15 PM.. Reason: more info |
04-05-2011, 07:03 PM | #4 |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
PM'ed you
04-06-2011, 12:40 PM | #5 | |
252
Rep 7,089
04-06-2011, 04:57 PM | #7 | |
pullin a boat
37
Rep 479
2021 X3 M40i, Phytonic/Cognac Past: 2017 330i xDrive Touring M Sport, EBII, Dinan 2014 328d xDrive Touring M Sport, BSM/CR. |
04-06-2011, 07:38 PM | #9 | |
555
Rep 1,244
Drives: 2013 F10 M5
Most eBay sellers are starting to catch on and start offering cables with the pins disconnected and supply an adapter for older cars to link pins 7 and 8. See one of my earlier threads for a list of chassis requiring the adapter. |
