1st time at the track bmw 335i sedan auto
04-05-2011, 02:17 AM | #1 |
Rep 135
1) 2008 Sedan BMW Automatic with Step
2) Temp 88-82 Degrees 3) AA downpipe, Vanguard Exhaust, HPF Intercooler, ESS Stage 2 Tune. 4) 91 Octane, A little bit under 1/4 Tank 5) After the first run my weight reducing was removing the passenger. 4) Stock Tires 17 inch Run Flats 5) Driving auto for awhile now, just 1st time at the track with this car. 6) I'm attaching pictures of the first two passes. My first pass was a 13.2 with a passenger. My second run was a 12.9 without a passenger. My third run was 13.5 without a passenger, mainly due to no traction what so ever. Do you guys have any suggestions to get a lower 1/4 mile time? All of the runs were done in sport mode and launching was on m2. My first run i launched at 1500, second at 1800, third at 2000 and i spun a lot. Each run i just floored it all the way down the strip. |
04-07-2011, 05:00 PM | #4 |
106
Rep 728
It was so obvious, I was gonna say Reaction Time until I saw the 2nd time slip which was better. Do you have LSD? That and tires
I think you still have a tiny bit to shave in your R/Ts. I don't have much experience myself, but I think mine was like 0.17x or 0.2xx the first and only time I went. Thanks for sharing.
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
04-07-2011, 07:47 PM | #6 | |
e92
Rep 391
to echo others, stock rfts are probably slowing you down the most |
05-09-2011, 09:29 PM | #8 |
street racer
16
Rep 433
Cali does not have 93 right ?
Meth kit, some tires R888 or real DRs, and LSD |
05-12-2011, 02:29 PM | #10 |
88
Rep 1,404
x2 on the tires.
LSD is a expensive mod, but will offer huge reduction of tire slippage.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
