Bi-xenon headlight replacement need re-programming?
04-02-2011, 07:48 PM | #1 |
12
Rep 157
Drives: 2007 328i e90 - 2015 X3 F25
i've got an e90 2007 328i w/ Bi-xenon. i had my solenoid changed at a local bmw dealer (under warranty) and had to leave my car overnight. when i got my car back the next day, my right headlight lens had a spiderweb-like crack. dealer told me today they're gonna replace it, under warranty.
the after-sales guy at dealership told me that once the assembly is in and ready for installation, they would re-program my headlights. i thought that that was not necessary as it would just be a direct swap, and that my orig right headlight is working fine. guy said the new headlight needs programming to ensure the adaptive HID will work. is it true that if you're replacing one of your HID headlight assembly (due to cracked lens), you need to re-program the new headlight to get the adaptive HID working? tnx for any input.
My other BMW.
04-02-2011, 10:04 PM | #2 | |
NHTSA Nazi
28
Rep 1,983
04-03-2011, 12:01 PM | #4 | |
NHTSA Nazi
28
Rep 1,983
IIRC, the Canadian law does not require a certain lighting unit to function as the DRL; it just defines the brightness of the DRL as being less than a headlamp. You might want to check the current Canadian law to be certain. But yes, you'll probably need to get recoded if you want your corona rings on again. |
