The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Changed the plugs after 35k miles
      04-02-2011, 04:45 PM   #1
PKumarM3
Air India
India
145
Drives: 2018 Dodge Durango
Followed the DIY located here: http://www.e90post.com/forums/showth...ght=spark+plug
Tools I used:
ECS BMW Spark Plug Socket
10inch 3/8 extension
3/8 ratchet
Long flat nose screwdriver
LONG needle nose pliers
3/8 Torque Wrench (harbor freight)
Took about one hour and I was taking my sweet time. The coils were not as difficult as I thought they were going to be to install. 3-4-5 took me some time since they were not as easy to remove the cover, but using a flat nosed long screwdriver, i was able to slide the screwdriver through the cap and pull straight up (don't twist or else you can break the nipple).
The other thing that I used was a long needle nose plier to remove the spark plug once it was unscrewed. After that everything was quite simple. Torqued the plugs down to 17lb/ft tq.
I was experiencing some cylinder 5 misfires over the past 2 months which was concerning. I decided that the spark plugs would be the first item I would tackle and if the misfires kept up I would take it in for service. My car is an 09/08 build. I contacted my dealer to see if I were eligible for the injector recall and they said no - but I understand it requires a tech to inspect each injector. We'll see what happens.
So far, the car feels better. Maybe its the butt dyno, but the car feels better. There are also no hiccups on start up. Definitely is healthier. My car had 35,100 miles on it. I think this is a maintenance job that I would do every summer. Its $60, which is quite cheap.
Here are two pics:
old vs. new
ewwww
Its a quick and easy job. Also cheap. Cheaper than an oil change! I don't see why you wouldn't want to do this
Ordered the sparkplugs from Autohausaz.com - came out to around $65 or so shipped.
PKumarM3
      04-02-2011, 04:54 PM   #2
DefactoM6
Sees the world the way it could be
49
Drives: '88 M6, '02 Z8, '09 E92 335i
Lemme guess...2nd in from the right came off of #5...injector time!
Seriously though...definitely was due for plugs, and it probably wasn't just the butt dyno.
      04-15-2011, 12:54 AM   #3
vase330
vase330's Avatar
102
Drives: 19 E63S; 15.5 RangeRover ATB
Reminds me i need to do mine soon.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      04-15-2011, 01:17 AM   #4
creaminz
creaminz's Avatar
545
Drives: E90 LCI
I changed my plugs every 20K. People say overkill, I say good job creaminz.
      04-15-2011, 01:46 AM   #5
McMuffin
McMuffin's Avatar
104
Drives: A Widebody 92
Just like I change my oil every 2k or so
Embryo>e92
      04-15-2011, 09:38 AM   #6
flyers1470
Drives: 335i
OP, you said you were experiencing some cylinder 5 misfires (which I've heard others say they've experienced as well). How are you able to determine this?
      04-20-2011, 10:48 AM   #7
PKumarM3
Air India
India
145
bav technic diagnostic tool
have put on 1k miles on the car since the plugs - no more hiccups during start up!
PKumarM3
      04-20-2011, 12:06 PM   #8
KyLu II
FREE DREAMK
Dominican Republic
162
Drives: the shiiit!
2011 Lexus LFA  [3.76]
Got mines done yesterday, no more misfies on full throttle!! 32k miles and about 20k tuned. I would Defenetly change it every 15-20k miles if tuned. Plugs get fouled quick due to blow by vapors....
      04-20-2011, 12:19 PM   #9
99three
25
Drives: 993, e92, e36, F355, Z32, Jag
Are there any colder plugs for cars yet?
      04-20-2011, 12:30 PM   #10
bluecusion
South Korea
57
Drives: X5M competition
diy link does not work..
      04-20-2011, 12:32 PM   #11
KyLu II
FREE DREAMK
Dominican Republic
162
Drives: the shiiit!
I believe I saw someone on here put some NGK but I think they had issues it it. Can't remember. Do a quick search I'm sure you will find the thread...
      04-20-2011, 12:33 PM   #12
KyLu II
FREE DREAMK
Dominican Republic
162
Drives: the shiiit!
Instead of clicking it try to copy the link and pasting it on the address bar!
      04-20-2011, 12:33 PM   #13
gboop
Drives: 335i
Those plugs look identical to mine when I had my misfires and changed at 40,000.
My misfires were also primarily on cylinder 5 and only with a tune.
Anybody know why cylinder 5 is such a common cylinder to misfire?
      04-20-2011, 12:54 PM   #14
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
When is BMW supposed to change the plugs? In my owners manual, IIRC, it is stated that for N54 the spark plugs should be replaced every 25K miles. Now, wouldn't that fall under free maintenance?
I have some cold start misfires which very quickly go away. I've been waiting to turn 25K miles to bring my car in to the dealer to get new plugs. Should I just replace mine on my own, or fight with the dealer?
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      04-20-2011, 02:55 PM   #15
gboop
Drives: 335i
I was told by a tech that it's a condition based service that usually gets triggered after the warranty runs out.
http://www.e90post.com/forums/showthread.php?t=491327
My cold start misfires were resolved by leaky injector replacement.
My high-rpm misfire was solved by spark-plug replacement.
      04-20-2011, 03:18 PM   #16
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
When my car misfired on Procede it was almost always cylinder 6.
E90 LCI N54 6AT
      04-20-2011, 03:34 PM   #17
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
Mine is always cylinder 6 too. I suspect I have a leaky injector.
Fix your broken/stripped cowl bolts with this elegant brass solution!
http://www.e90post.com/forums/showthread.php?p=20230306
      04-20-2011, 03:43 PM   #18
Perfectus
Perfectus's Avatar
35
Drives: e92 335i/F10 528XI
Is there a test on the BavTech tool that determines which cylinder the misfires are happening in? Or is it just a general code thrown by the engine?
I'm trying to prove to my dealer that I need some or all new injectors, but my car does not fall under the TSB.
I need to replace mine. I already ordered the plugs and tool, just waiting for the weather to be right.
2012 528XI Saphire Black
Stock for now
2007 e92 335i - Monaco Blue
Injen DCI w/ Cyba Scoop - M-Tech Rear - ///M3 Rear Lip Spoiler - ///M5 SMG Shift Knob & iDrive Knob - BMW Performance Hand Brake - BMWCCA Member
      04-20-2011, 04:04 PM   #19
wren57
Roll Tide
wren57's Avatar
591
Drives: 335i
The tool gives you a code. Each code corresponds to one cylinder.
      04-20-2011, 04:48 PM   #20
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Originally Posted by Perfectus View Post
Is there a test on the BavTech tool that determines which cylinder the misfires are happening in?.
You can monitor each spark plug and log the number of misfires it detects. If the misfires are above a certain average, the ECU will throw a misfire code. However, you can easily spot a failing plug by looking at the number of detected misfires and compare those values with the values you get from the other spark plugs.
      04-20-2011, 05:04 PM   #21
timmahh
ghey
timmahh's Avatar
483
Drives: Viertürigen Fahrzeugs
Service/owners manual states 335 should have spark plug changes every 45k miles.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
      04-20-2011, 09:50 PM   #22
Bakeme521
Some say...
Bakeme521's Avatar
239
Drives: Fresh
2007 BMW 335i  [8.24]
I changed mine at 45k and i was having terrible misfires, all has been well since.
I have exhaust and an intake...
