Tint glare over defroster lines
03-12-2007, 08:25 AM | #1 |
Rep 89
I apologize if this has been covered elsewhere. I did a search and went through lots of threads but couldn't find this topic covered in them.
I got my windows tinted a few weeks ago and the rear window seems to be a problem area. They're going to have to redo it since I found a pretty big flaw that wasn't visible until the windows were finally cured. That will be taken care of by them but my issue is that now that there is tint on the rear window I'm seeing a lot of glare from headlights and street lights due to the tint over the defroster lines. The headlights kind of have a mirror effect up and down the defrost lines now. Is this common or did they just hose up the tint job? Like I said, they're going to redo it tomorrow but I was just wondering if this is something I'm going to have to live with to have tinted windows. I read in a lot of posts that the rear window is a PITA to tint so maybe this is just a known issue. Thoughts? Thanks! |
03-12-2007, 08:33 AM | #2 |
E60
39
Rep 587
sounds like a botched job... whats the weather like? and how longs a few weeks? if its cold out then it takes a longgggggg time for the tint to settle. the glare could be from it just not being dry yet. if its above 60 then get it retinted cuz it should dry in a week, and bring up that the fact that if they ruin ur defroster lines they need to replace them... good luck!
03-12-2007, 09:38 AM | #5 |
40
Rep 481
i thought like theres no way to fix the distortion of light against the rear window because the defroster lines are elevated from the tint. so theres more refraction of light as it tries to pass through the window and therefore more light going up/down. hahah or at least what my tint guy told me. . . . O.O
MY10 335d: Montego Blue, Oyster/Black Leather, Aluminum Trim, Navi, ZSP with Paddle Shifters, ZCW, Alarm
Order Placed: Aug 15th, In Production: Sept 1st, At Port of Exit & Awaiting Transport: Sept 15th, Sept 16th, At Prep Center: Oct 7th, Released to Carrier: Oct 22nd, Delivered: Nov 11 |
03-12-2007, 10:11 AM | #6 |
Rep 89
I got 35% tint all around. It's supposed to be warmer, relatively speaking, this week so we'll be in the 50s and 60s. We'll see how they do with tomorrows re-do and I will definitely bring up the "don't screw up the defroster" point.
03-14-2007, 02:48 PM | #7 |
31
Rep 746
Drives: 2007 328 Coupe Alpine White
03-14-2007, 06:36 PM | #8 |
Rep 143
Drives: e92 335i Sparkling Graphite
I get a little glare from the defroster lines. When i look closely, there is space around the defroster lines. Is that normal? Also the dot matrix stuff came out pretty bad at the top of the window. Should I have my guy re-do it? It's been about 3 weeks and weather is relatively warm in CA, altho I park inside most of the time.
03-15-2007, 12:14 PM | #9 |
13
Rep 247
I have the same light deflection around the lines. I hate it and the dotmatrix crap looks like hell. I talked to another tint guy about the dotmatrix and his advice was to use a bunch of glue in that area. It will make it look good from the outside, but will be blury to look through from the inside. Anywho, if that light deflection thing is NOT normal I'm going back to my tinter.
2007 335i Coupe |
02-04-2011, 09:35 PM | #10 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Going to go back to the tint guy to get felt tape installed in the side windows and the tint redone to get rid of those scratches.
I have this same issue too... My windows have been tinted for more than 7 months. Is this problem fixable or do I just have to deal with it? Should I even bother asking him about it? Found a picture on Google that shows it perfectly: Also, from another thread: |
