sooo..what else can possibly go wrong?
03-29-2011, 04:46 PM | #1 |
23
Rep 188
Ok, when I first bought my 335i I did a little research on what problems they were prone to having...
* The issue that kept coming up was the HPFP....no biggie! I got that replaced after the recall was sent out at 60,000 Miles * Now my Water Pump went bad...I did intensive research and come to find out a lot of people have their water pumps fail around 60,000 miles (I am at 62k) * My Oil Filter Housing is leaking oil! I need to replace the gasket..did some research and apparently this happens to a lot of people * My DMTL pump has gone bad and is causing my Check Engine Light to come on.. So far things to look out for : 1)HPFP 2) Water Pump 3) Oil Filter Housing 4) DMTL pump My question is.... what OTHER problems should I be anticipating as I start putting more miles on my car...Turbos? Wastegates? Fuel Injectors? anything like that, what should I be concerned about...!?Would you guys recommend I do a cleaning of the fuel system or any other pro-active services to my vehicle so I don't run into trouble down the road? & Lastly... How much were you charged to replace the gasket on your oil filter housing? I know there is a DIY on it but I do not have access to a garage =( |
03-29-2011, 05:02 PM | #2 |
76
Rep 1,883
My problems thus far (currently at 43k miles):
1. 3rd set of fuel injectors 2. replaced water pump (around 40k miles) 3. replaced power steering pulley, belt and subframe from belt/pulley contacting subframe, apparently there is a SIB on this (@43k miles) 4. replaced battery (around 35k miles)
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
03-29-2011, 05:24 PM | #6 |
113
Rep 1,347
Drives: 2011 335d
I need to sell this car and buy another e36... at least they're cheap to fix lol
03-30-2011, 06:49 AM | #8 |
Saving lives one shift at a time
19
Rep 309
Ok my car is a 2008 E90 with 44000 now. Here is my list.
1. Lower control arms upper arms to I think. 2. Strut mounts 3. Water pump 4. HPFP x's 2 5. LPFP 6. 6 injectors and plugs 7. Oil pan gasket 8. Rear Diff This was all in the last 12 months. Started with about 35000 miles. I think BMW had my car more then I did.
2008 335i...... 6AT....Sports package.... Premium package.....Cold weather package....i Drive....Nav....Sat radio....Logic 7.....PROcede v4 auto tune....Injen Intake
03-30-2011, 02:58 PM | #14 |
Regional Governor
26
Rep 556
Well, for starters your wastegates can go to shit. Then, your turbos would need to be replaced. Also, pins 18/19 in the driver's side a-pillar window control actuator could corrode and cause your windows, sunroof and trunk to randomly roll down at the worst times.
But other than what's been mentioned, I honestly can't think of anything! |
03-30-2011, 03:58 PM | #15 |
16
Rep 159
So far I've went through
- 3 HPFPs (on #4 now) - 1 LPFP - 2 door actuators (same one broke at different times) - 1 Radio/CD player - Injectors and before I got my RB Turbos installed, my original wastegates we're making a load of noise and needed replaced. I have 50K miles on a 2007 E90. A. |
03-30-2011, 09:04 PM | #16 |
45
Rep 649
so far
-1 hpfp -2 seatbelts -thermostate -6 injectors -2 front headlights -both turbo's replaced -clutch was defective changed at 2400 miles -4 right rear taillights -left front brake caliper had some issues forgot what they changed it i think -rear sway bar came loose... also i would like to add my car is drivin hard it has 44k miles.. thers more stuf i have the full prinout CPO is the shizzznaz.... Last edited by MikeyComputers; 03-31-2011 at 12:18 AM.. |
03-31-2011, 11:55 AM | #18 |
37
Rep 381
I've got an '07 e90 w/ 30K miles. Only problem has been with the VANOS solenoids causing dreaded limp mode at the track this spring. It's not an uncommon problem.
