Overboost Help
03-27-2011, 10:31 PM | #1 |
34
Rep 1,284
Overboost Help
At high boost getting an overboost, car hesitates until it goes into limp mode , I'm pretty sure it's a vacuum leak, checked both bov and stock diverter valves looks OK to me, but happens with both sometime after 11 psi , is there anyway to do a vacuum leak test in the shop ? besides just looking at the hoses ? Maybe it's my wastegate actuators ? How can I check ? This drives me fucking crazy !!!!!
03-27-2011, 11:22 PM | #3 |
34
Rep 1,284
03-28-2011, 07:50 AM | #6 |
14
Rep 284
Thought u were asking for my help But I would think overboosts would have something to do with wastegate actuation. See if u can check the hoses going to the actuators. Don't quote me on this but if one of the hoses are off or leaking then the actuator may keep the wastegate closed.
PROCEDE V5, AR CATLESS DP's, HELIX FMIC, ER CHARGE PIPE AND TIAL BOV, OHLINS ROAD AND TRACK COILOVERS, INJEN INTAKE, AWD TURBO UPGRADE, VISHNU PWM METHANOL INJECTION, AMS CATBACK EXHAUST, M3 FRONT SUSPENSION COMPONENTS,VOLK RE30 19X9F 19X10R W/ YOKOHAMA ADVAN AD08 265/275
03-28-2011, 07:51 AM | #7 | |
34
Rep 1,284
03-28-2011, 07:55 AM | #9 |
161
Rep 7,377
check all the small hoses from the 2 canister of the boost control . those are located on passenger side . is basically where you attach the AR oil catch can.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-28-2011, 08:39 AM | #11 |
ElevenPointFive
327
Rep 2,450
Cold side FMIC connector was my issue as well when I had overboost codes.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
