procede settings help
03-26-2011, 10:43 AM | #1 |
27
Rep 309
Hello
I am full bolt on car with meth. I just recently put the vishnu meth kit on my car. I turned it to map 4 and set my boost to 17 psi. I keep getting overboost codes from the procede. I have researched everywhere and i cant figure out what my settings should be. Any help would be greatly appricaited I have attached a snapshot of my settings. sorry for the crappy cell phone picture. |
03-26-2011, 11:03 AM | #2 |
442
Rep 18,331
On map 2 you need To set maximum boost to 18. You have your boost set to 17 already so you are triggering the overboost valet on the procede. 70 as a starting boost yield you 17psi which your boost maximum is 17 already. Hope that makes sense!
03-26-2011, 11:05 AM | #3 |
161
Rep 7,377
Set max boost on map 2 to 18. Is that software version 5? Did you change overboost delay to 18? Normally should be 10 i think .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-26-2011, 11:07 AM | #4 |
24
Rep 563
On observation , i noticed:
you have max boost at 17.0 and start boost at 17. I would lower starting boost to 16(60) on map 2. A little fluctuation over 17psi is causing your issue. Give that a shot. I also would lower map 1 max to 14 psi and start psi at 13. |
03-26-2011, 11:13 AM | #5 |
161
Rep 7,377
Autotune is enabled so he has to hit 17 psi straight away . I would also lower iC to 0% on map 2
03-26-2011, 11:20 AM | #6 |
27
Rep 309
Hello thank you so much for all the resposnes. Auto tune is off due to this being a beta dic map. So should i still turn ic to 0%? As soon as i have a change to go to my buddies shop to hook the laptop up i will change the settings and report back. Thanks again.
