Vishnu DP - CEL- after install
03-25-2011, 09:18 AM | #1 |
Rep 92
Drives: 2011 335xi
Well the title pretty much explains it all. I know there are a few guys on the forum running the N55 DP. I know the CEL is due to the DP. But isnt there a way to bypass it from coming on with the procede. I already tried adjusting the O2 modifier its act to 0 % and the CEL still came on after a day of drive. Check the install no leaks , car feels great just would like to get the CEL off my dash. Any ideas?
Edit* I have not install the updated harness and software yet.
2011 Black 335 xi MT- M package- Cold weather- BMW Performance Grills-PIAA H8 yellow fogs-Procede V5-Vishnu DP 3.5 inch- CDV delete-Vishnu Charge Pipe - ***Waiting on meth kit*** - H&R Springs Sport Kit
03-25-2011, 11:09 AM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
There is no o2 modifier function with the n55 application. CANclear, if left on, will keep the catless code (12550) from lighting up the SES light. I suspect you are seeing another code. You'll need to read it. It may be due to improper installation.
03-25-2011, 12:29 PM | #3 |
Rep 92
Drives: 2011 335xi
Hey Shiv thanks for getting back to me . I just hooked up my laptop and im getting dme codes 12253 and 12550. CanClear is turned on. And I do see under my user setting a 02 modifier field (0%-100%)
03-25-2011, 12:32 PM | #4 | |
1737
Rep 17,960
Drives: A Lot
I'm thinking the SES light was caused by something else which has now been cleared. But requires a few drive cycles to turn off. The o2 modifier adjustable has no effect btw. Shiv |
03-25-2011, 12:36 PM | #5 |
Rep 92
Drives: 2011 335xi
No after clearing the code the SES light is off . It lasts for a day , then comes back on.
03-25-2011, 12:42 PM | #6 | |
1737
Rep 17,960
Drives: A Lot
If so, just drive around normally and after 1/2 a day (before the SES light comes on), check your codes and let me know if you see the 12250 code. Basically, what I need to know is if the 12550 code is triggered before the SES light is lit (which is what I expect). Unless BMW changed this with some recent (within 2 weeks) DME update. Shiv |
03-25-2011, 12:44 PM | #7 | |
Rep 92
Drives: 2011 335xi
03-26-2011, 09:01 AM | #8 |
Rep 92
Drives: 2011 335xi
Hey Shiv cleared the code the car was good all night. I had the laptop hooked up to it. This morning on my way to work the SES came back on with the cat code. I dunno what to do. I cleared the fault again and reset all the adaptations.
03-26-2011, 11:57 AM | #9 | |
1737
Rep 17,960
Drives: A Lot
Are you running a very new BMW software update released within the last 2-3 weeks? |
03-26-2011, 12:08 PM | #10 | |
Rep 92
Drives: 2011 335xi
03-26-2011, 12:19 PM | #11 | |
1737
Rep 17,960
Drives: A Lot
For CANclear to work, the code must be logged by the Procede before the dash light comes on. It clears/resets the code while it is in this temporary invisible state. If there is no temporary invisible state, it won't work. Shiv |
03-26-2011, 01:10 PM | #12 |
Custom Powder Coater
147
Rep 2,784
Hey Shiv, what's outlet pipe diameter of the turbo manifold for the N55?
03-26-2011, 01:15 PM | #13 |
1737
Rep 17,960
Drives: A Lot
03-26-2011, 01:18 PM | #14 |
147
Rep 2,784
No.
Where the downpipe bolts up to
