help keep going into limp mode with jb4
03-25-2011, 12:30 AM | #1 |
35
Rep 510
as it states when i take traction control off in second wot till 3 it goes into limp mode car shakes and sells service engine soon turn off car everything seems fine after .... ne suggestions ob what can be going wrong
03-25-2011, 12:34 AM | #2 |
Rep 448
Did you do the prewiring yourself? Might want to double check that and make sure all your wires are in the right spot.
Procede, AFE Intake, AA BOV, Black Out Tail Lights, Black Grills, Black side reflectors, VMR V715s 19", VSRF Catless-DownPipes and FMIC. Coming soon - Metch rear bumper,, Oil Catch Can, and much more.
03-25-2011, 06:48 AM | #4 |
2054
Rep 6,114
You might want to post this either in the engine mods section or over on n54tech.com. That way you will have a better shot of Terry seeing this thread. Or just email him. Good luck!
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
03-25-2011, 08:50 AM | #5 |
196
Rep 2,485
What other mods do you have?
What map are you running? Plug and Play or Pin Out wiring?
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
03-25-2011, 12:57 PM | #6 |
161
Rep 3,736
^This
03-25-2011, 01:14 PM | #7 | |
Joint Chiefs of Staff
4919
Rep 115,980
I don't get why people make these threads without taking the 3 seconds to read the actual codes first. Mike |
03-25-2011, 02:02 PM | #9 |
Rep 200
The traction control off may not be part of the issue - ive been having a problem when going wot at ~3k it goes into limp - havent ran the code yet but it is similar to a previous problem ive had with vanos - just a couple of solenoids and about to put them in - hopefully clears up the issue
stockeroni and cheese?
03-25-2011, 02:27 PM | #12 |
Custom Powder Coater
147
Rep 2,784
Turn off auto clear. I never have that on for that very reason.
03-25-2011, 02:31 PM | #13 | |
4919
Rep 115,980
Mike |
03-25-2011, 03:02 PM | #14 |
224
Rep 699
Yea turn off auto-clear it throws up all kinds of codes. Id reset the battery too that always helps me.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
03-25-2011, 05:00 PM | #17 |
Rep 101
I just had the same issues. Took JB4 out, went to dealership, and it better now. Just needed the new HPFP and New Injectors which were both on recall.
08' Black Sapphire E92 / Coral Red / Eibach Sports / AFE Dual Cone |
04-08-2011, 12:23 AM | #18 |
Rep 150
I have dual cone intake and JB4, both installed this week. Monday I had the HPFP replaced and 5 injectors.
Tonight at WOT in 6th gear at about 145mph, the car gave me a malfunction (1/2motor) message and I had no power. Map was set to five. Oil temp was one notch below 250. I stopped car and turned it back on and everything appeared normal.
2008 335i Coupe TiAg - Cold Weather - Premium - Sport - Style 230 19's - SatNav - Active Steering/Cruise - Comfort Access - PDC
04-08-2011, 08:00 AM | #19 | |
34
Rep 1,284
04-08-2011, 08:06 AM | #20 | |
4919
Rep 115,980
Mike |
