Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Possible to activate cruise control set speed in display?
      03-23-2011, 10:36 PM   #1
Moonstone
Moonstone's Avatar
Australia
14
Drives: E90 320i M-Sport
Possible to activate cruise control set speed in display? - Yes it can be done!
I have just started coding my '06 E90 and was wondering if it is possible to code the set speed display for the cruise control to come up in the info. display when you activate it. I don't have the active cruise control but I know this is possible as I have driven a 2010 LCI without ACC that would display the set speed.
Thanks in advance for any assistance provided and hello to all who read from down under.
Last edited by Moonstone; 03-30-2011 at 05:19 PM.. Reason: Indicate that issue has been resolved.
      03-23-2011, 11:35 PM   #2
Patsfan123
Patsfan123's Avatar
14
Drives: 2007 328xi Coupe
Mine flashes on for a second when I set it, but it doesn't stay up the whole time? Is this what you are talking about?
2007 328xi Coupe | TiAg | Steptronic | Premium | Sport | Nav | Comfort | Cold Weather | BMW Sport Exhaust | BMS PBX | Euro Airbox w/ K&N | Eibach/Bilstein | RDash LED License Plate
      03-23-2011, 11:46 PM   #3
Moonstone
Moonstone's Avatar
Australia
14
No nothing on mine, that is what the LCI I drove did. It is really annoying not having any indication the cruise control has engaged. Cruise control works OK though. I asked my dealer if this was a fault with mine but was told only on the LCI's did it display the set speed for a second or so.
      03-24-2011, 07:33 AM   #4
Dracon
555
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
Maybe it's a regional thing then. I have a 2006 330i E90 and mine displays the set speed on the display when I hit the control stalk to activate the cruise control, it also puts a little bar on the analog speedo on the mileage I'm set at until I either change speed or turn it off. It also shows me the display when I use the stalk to adjust the cruise control speed, either adjusting up or down.
      03-25-2011, 12:39 PM   #5
Toad335
32
Drives: LCI 335i
This would lead me to believe it's possible to code, but I don't have any idea how. Makes this post kinda useless, other than to convince others to explore / compare their TRC vs moonstone's. Moonstone, can you post your full car TRC for folks to compare that do have this function.
      03-25-2011, 08:00 PM   #6
Moonstone
Moonstone's Avatar
Australia
14
Good idea Toad335. Here is a copy of my TRC file if anyone more knowledgable than myself is interested in comparing. Thanks again.
M-Sport Pack | BMW Individual Paint - Moonstone | BMW 193 18" Wheels | BMW Individual Interior Trim - Anthracite Maple
      03-28-2011, 08:37 AM   #7
Toad335
32
Drives: LCI 335i
Can you post just your KOMBI.TRC? I have a feeling it's in there if it's anywhere...
      03-28-2011, 06:00 PM   #8
Moonstone
Moonstone's Avatar
Australia
14
Here is my KOMBI.TRC file.
      03-28-2011, 06:18 PM   #9
woodpecka
woodpecka's Avatar
68
Drives: E91
I have a 325XI 2006 and I can see the speed in the cluster for 1-2 sec.
I tried to compare my KOMBI with yours but there is too much differences.
CC_BLINKFREQUENZ_LANGSAM
wert_01
CC_BLINKFREQUENZ_SCHNELL
wert_01
TANK_FILTER_FALLEND
wert_02
CC_15_EIN
benzin
CC_15_AUS
wert_01
CC_R_EIN
wert_01
CC_ML
wert_01
PREDRIVE_PERIODENDAUER
wert_01
TANK_FILTER_STEIGEND
wert_02
TANK_MITTLUNGSZEIT
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
TANK_SICHERHEITSFAKTOR
wert_01
TANK_RED_REICHWEITE
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
AUSSENTEMP_ZEITKONST_Z5
wert_01
AUSSENTEMP_ZEITKONST_Z6
wert_01
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_ANZ_FEHLER_1
wert_01
AUSSENTEMP_ANZ_FEHLER_2
wert_01
PREDRIVE_ABB_MOT
nicht_aktiv
BC_V_KORREKTUR
aktiv
WARNFELD_INFO_DME
aktiv
DSC_ALIVE_ZAEHLER
aktiv
DME_ALIVE_ZAEHLER
aktiv
CAS_ALIVE
aktiv
LM_ALIVE
aktiv
BC_DIGITAL_V
nicht_aktiv
BC_DIGITAL_V_KORREKTUR
aktiv
ZGM_ALIVE_ZAEHLER
aktiv
TNK_LITER_RECHTS
wert_02
wert_05
TNK_LITER_LINKS
wert_02
wert_05
TNK_OHM_RECHTS
wert_02
wert_05
TNK_OHM_LINKS
wert_02
wert_05
TANK_RW_WARNUNG
wert_01
ACC_FILTER_FALLEND
wert_01
ACC_FILTER_STEIGEND
wert_01
ACC_ZEIGER_AUF_NULL
aktiv
AUSSENTEMP_SPERR_FAKTOR
wert_01
AUSSENTEMP_SPERR_OFFSET
wert_01
CC_R_AUS
wert_01
CBS_STAT_01H
anzeige
CBS_STAT_02H
anzeige
CBS_STAT_04H
anzeige
CBS_STAT_03H
anzeige
CBS_STAT_10H
anzeige
CBS_STAT_11H
anzeige
CBS_STAT_20H
sperre
CBS_STAT_21H
sperre
CBS_GELB_HUAU
wert_01
CBS_RES_SPERR
wert_01
CBS_AVKM_START
wert_01
CBS_GELB
wert_01
CBS_STAT_12H
sperre
CBS_STAT_06H
anzeige
CBS_STAT_07H
sperre
CBS_STAT_08H
sperre
CBS_STAT_13H
sperre
CBS_STAT_14H
sperre
CBS_EINH_01H
wegzeit
CBS_EINH_02H
wegbas
CBS_EINH_04H
wegzeit
CBS_EINH_06H
wegbas
CBS_EINH_07H
wegbas
CBS_EINH_08H
wegzeit
CBS_EINH_03H
zeitbas
CBS_EINH_10H
wegbas
CBS_EINH_11H
wegzeit
CBS_EINH_12H
wegbas
CBS_EINH_13H
zeitbas
CBS_EINH_14H
zeitbas
CBS_EINH_20H
zeitbas
CBS_EINH_21H
zeitbas
SFY_ALIVE_ZAEHLER
aktiv
CC_ID_AKTIV
wert_03
CSUM_WEG
grundcode_var
CODING_VALID_BMW
wert_01
ACC_ALIVE_ZAEHLER
aktiv
ACC_AUSSTATTUNG
wert_03
AFS_ALIVE_ZAEHLER
nicht_aktiv
BC_2_ENABLE
aktiv
BC_LIMIT_ENABLE
aktiv
CC_TEMPERATURWARNUNG
nicht_aktiv
WARNUNG_GESCHW_LIMIT
nicht_aktiv
CC_BREMSWARNL_NUR_ROT
nicht_aktiv
CC_ZUENDSCHLUESSEL
aktiv
TANK_SCHWELLE_RESERVE
wert_01
KUEHL_MTL_AKTIV
aktiv_high
GPS_UHR
nicht_aktiv
K_ZAHL_TACHO
wert_02
K_ZAHL_TACHO_KOMPL
wert_02
K_ZAHL_WEG
wert_02
K_ZAHL_WEG_KOMPL
wert_02
AHM_ALIVE
nicht_aktiv
ARS_ALIVE_ZAEHLER
nicht_aktiv
RDC_ALIVE
nicht_aktiv
GETRIEBE_ART
automatik
EGS_ALIVE_ZAEHLER
aktiv
ACC_CSUM_MONITOR
nicht_aktiv
ACC_ID_MONITOR
aktiv
AFS_ID_MONITOR
nicht_aktiv
ARS_ID_MONITOR
nicht_aktiv
BC_LEERZEILE
aktiv
CBS_GELB_KM_MIN
wert_01
CBS_INTD_03H
wert_01
CBS_INTW_10H
wert_03
wert_06
CBS_INTW_11H
wert_02
CBS_INTW_12H
wert_01
CBS_SCEN_01H
nicht_aktiv
CBS_SCEN_02H
nicht_aktiv
CBS_SCEN_03H
nicht_aktiv
CBS_SCEN_04H
nicht_aktiv
CBS_SCEN_06H
nicht_aktiv
CBS_SCEN_07H
nicht_aktiv
CBS_SCEN_08H
nicht_aktiv
CBS_SCEN_10H
nicht_aktiv
CBS_SCEN_11H
nicht_aktiv
CBS_SCEN_12H
nicht_aktiv
CBS_SCEN_13H
nicht_aktiv
CBS_SCEN_14H
nicht_aktiv
CBS_SCEN_20H
nicht_aktiv
CBS_SCEN_21H
nicht_aktiv
CBS_TZ_SCHALTER
borddatum
DATEN_INDEX
wert_01
DME_ID_MONITOR
aktiv
DSC_ID_MONITOR
aktiv
EGS_CSUM_MONITOR
aktiv
EGS_ID_MONITOR
aktiv
EHC_ALIVE
nicht_aktiv
EKP_ALIVE_ZAEHLER
nicht_aktiv
EKP_ID_MONITOR
nicht_aktiv
EPS_ALIVE_MONITOR
nicht_aktiv
EPS_ID_MONITOR
nicht_aktiv
FDC_VERBAUT
nicht_aktiv
HU_VERBAUT
radiostufe_2
LEHNE_BF_ALIVE_ZAEHLER
nicht_aktiv
LEHNE_BF_ID_MONITOR
nicht_aktiv
LEHNE_FA_ALIVE_ZAEHLER
nicht_aktiv
LEHNE_FA_ID_MONITOR
nicht_aktiv
MOTORKONSTANTE
wert_01
PREDRIVE_START_MIT_OBD
aktiv
SFY_ID_MONITOR
aktiv
TANK_OHM_FEHLER_OG
wert_01
TANK_OHM_FEHLER_UG
wert_01
TANK_VOLL_ERKENNUNG
wert_03
wert_04
TCM_ALIVE_MONITOR
nicht_aktiv
TCM_ID_MONITOR
nicht_aktiv
TEMPOMAT_SETZ_ANZ_DAUER
wert_02
ZGM_ID_MONITOR
aktiv
AKUSTIK_V_X
wert_01
AKUSTIK_V_Y
wert_01
CBS_INTD_11H
wert_01
CBS_INTD_13H
wert_01
CBS_INTD_14H
wert_01
KLACK_AMP
wert_01
KLACK_FRE
wert_01
KLACK_TON
wert_01
KLICK_AMP
wert_01
KLICK_FRE
wert_01
KLICK_TON
wert_01
SHOW_CC_MSG_NR
nicht_aktiv
SHOW_OEL_STAND
aktiv
HDC_VERBAUT
aktiv
MMI_ENA_PIA
aktiv
MMI_ENA_RPA_RDC
aktiv
MMI_ENA_UHR_DATUM
aktiv
RDC_VERBAUT
nicht_aktiv
K410D_C_WEG_1
wert_01
K410D_C_WEG_2
wert_01
K410D_C_WEG_3
wert_01
K410D_C_WEG_4
wert_01
K410D_D_WEG
wert_02
K4110_C_VERBRAUCH_1
wert_01
K4110_C_VERBRAUCH_2
wert_04
K4110_C_VERBRAUCH_3
wert_01
K4110_C_VERBRAUCH_4
wert_01
K4110_D_VERBRAUCH
wert_03
K4113_C_ZEIT_1
wert_02
K4113_C_ZEIT_2
wert_02
K4113_C_ZEIT_3
wert_02
K4113_C_ZEIT_4
wert_02
K4113_D_ZEIT
wert_02
K4116_C_TEMPERATUR_1
wert_01
K4116_C_TEMPERATUR_2
wert_01
K4116_C_TEMPERATUR_3
wert_01
K4116_C_TEMPERATUR_4
wert_01
K4116_D_TEMPERATUR
wert_02
K4119_C_DRUCK_1
wert_03
K4119_C_DRUCK_2
wert_03
K4119_C_DRUCK_3
wert_03
K4119_C_DRUCK_4
wert_03
K4119_D_DRUCK
wert_03
K430C_C_DATUM_1
wert_01
K430C_C_DATUM_2
wert_02
K430C_C_DATUM_3
wert_02
K430C_C_DATUM_4
wert_02
K430C_D_DATUM
wert_02
K4310_C_SPRACHE_1
wert_06
K4310_C_SPRACHE_2
wert_03
K4310_C_SPRACHE_3
wert_01
K4310_C_SPRACHE_4
wert_01
K4310_D_SPRACHE
wert_03
SITZ_L_UEBERWACHUNG
nicht_aktiv
CC_NR_ROLLE
aktiv
HDC_ID_MONITOR
aktiv
DSC_ALLRAD_CC_WAHL
aktiv
FDC_ID_MONITOR
nicht_aktiv
DIMM_MN_MAX
wert_01
DIMM_MN_MIN
wert_01
CRASH_TH_DIMMUNG
wert_01
DSC_MIT_RPA_CC
aktiv
DWA_VERBAUT
nicht_aktiv
FB_ALLE_TUEREN
aktiv
FB_FA_TUER
aktiv
HEIMLEUCHTEN_10S
aktiv
HEIMLEUCHTEN_150S
aktiv
HEIMLEUCHTEN_240S
aktiv
HEIMLEUCHTEN_40S
aktiv
HEIMLEUCHTEN_90S
aktiv
HEIMLEUCHTEN_AUS
aktiv
LICHT_AUT_WERT_1
nicht_aktiv
LICHT_AUT_WERT_2
nicht_aktiv
LICHT_AUT_WERT_3
nicht_aktiv
LL_RL_FZG
aktiv
OHNE_QUITT_ENT
aktiv
OHNE_QUITT_VER
aktiv
QUITT_AKUST_ENT
nicht_aktiv
QUITT_AKUST_VER
nicht_aktiv
QUITT_OPT_AKUST_ENT
nicht_aktiv
QUITT_OPT_AKUST_VER
nicht_aktiv
QUITT_OPT_ENT
aktiv
QUITT_OPT_VER
aktiv
SITZ_AUT_VERST_AUS
nicht_aktiv
SITZ_AUT_VERST_ENT
nicht_aktiv
SITZ_AUT_VERST_ENT_T
nicht_aktiv
TAG_LICHT_AN
nicht_aktiv
TAG_LICHT_AUS
nicht_aktiv
TIPP_BLINKEN_1X
aktiv
TIPP_BLINKEN_3X
aktiv
ZV_VER_AUS
aktiv
ZV_VER_FAHRT
aktiv
ZV_VER_FAHRT_ZEIT
aktiv
ZV_VER_ZEIT
aktiv
KL_PREDRIVE_AUSWAHL_2
wert_04
KL_PREDRIVE_AUSWAHL_1
wert_02
TANK_SCHWELLE_AUF_AB
wert_01
      03-28-2011, 06:40 PM   #10
Moonstone
Moonstone's Avatar
Australia
14
Thanks for that Woodpecka. I wanted to get hold of an '06 KOMBI file so I could compare myself, much appreciated.
      03-28-2011, 07:27 PM   #11
Moonstone
Moonstone's Avatar
Australia
14
I did a quick comparison in excel between woodpecka's and my KOMBI files. I haven't had a chance to look over it closely but hopefully will be able to pick up the necessary changes I need to enable the cruise control set speed display.
      03-29-2011, 12:21 PM   #12
Toad335
32
Drives: LCI 335i
The one that stands out most to me is TEMPOMAT_SETZ_ANZ_DAUER, which translates to CRUISE CONTROL SET TIME. I've also seen dauer translate to delay, so I'm thinking this might be the length of time that is shows on the display.
Mine is set to wert_02, yours is wert_01.
Others are TCM_ALIVE_MONITOR (yours nicht_aktiv, mine aktiv) and TCM_ID_MONITOR (yours nicht_aktiv, mine aktiv).
Try TEMPOMAT_SETZ_ANZ_DAUER and let me know if that works.
      03-30-2011, 05:15 PM   #13
Moonstone
Moonstone's Avatar
Australia
14
It works! I changed the following-
BC_2_ENABLE changed to aktiv
BC_LIMIT_ENABLE changed to aktiv
TEMPOMAT_SETZ_ANZ_DAUER changed to wert_2
I'm not sure if all three need to be changed, but comparing to woodpecka's file mine were different so decided to change then to see what changes there would be. When I have some more time I might try and isolate which one was required, probably as Toad335 suggested the TEMPOMAT_SETZ_ANZ_DAUER value. Thanks to you both for your help.
Now to see if I can get the Welcome lights to work, the car is a May '06 so I think I might be in trouble as the FRM module might not be capable.
      04-03-2011, 06:26 PM   #14
Moonstone
Moonstone's Avatar
Australia
14
Just to confirm back regarding my last post, only the following line needs to be change-
      04-03-2011, 06:37 PM   #15
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Moonstone, can you please add it to the coding spreadsheet by filling out this form?
https://spreadsheets.google.com/view...dZU1E6MQ#gid=6
Thank you.
      01-15-2019, 03:56 AM   #16
ozerux
Drives: E90 320d 120kw 2006
Hi everyone,
I will try to resurrect this post in 2019
I have retrofited Cruise Control in my 2005 e90 320d. One guy coded that feature to VO and now CC works as expected, but without any indication. My car has "low cluster". With NCS expert i tryied to change TEMPOMAT_SETZ_ANZ_DAUER value to wert_2 in kombi but without result.
Is it even possible to add this feature to KOMBI for such an old car?
What this ACC_AUSSTATTUNG do? It has 4 values from wert_01 to wert_04.
Maybe i need to code other models as well (as i mentioned above CC works)?
      01-15-2019, 09:59 AM   #17
ptpending
ptpending's Avatar
456
Drives: e91
on four cylinder cars you can only have one-time CC speed display when CC initiated or changed
six cylinder cars have cc speed indicator around speedometer
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      02-15-2019, 12:50 AM   #18
N52bigblock
99
Drives: 2005 E90 330i
Try setting the value to wert_02 instead of 2.
Originally Posted by ozerux View Post
Hi everyone,
      02-18-2019, 12:01 PM   #19
P14kle
196
Drives: E91
Just done this one... wert_01 is 0 sec
wert_02 is 3 sec
Thanks for the heads up. 😎
      02-19-2019, 06:13 AM   #20
P14kle
196
Drives: E91
Didn't work with me.. value is there in my trc file when I read it back, but nothing in display when activating the cruise control. ☹
I guess it's because I have a 'low Kombi' / instrument cluster which doesn't display this function.
      06-30-2020, 09:32 AM   #21
Teddy42TR
Drives: BMW E90
Tempomat_setz_anz_dauer
i have set TEMPOMAT_SETZ_ANZ_DAUER to 02 and tried, but without result.
when i read again from ncs expert its again on 01, it goes back to 01 itself, what am i doing wrong? what i have to do i really want the function to work to see what speed cruise is set on
bmw e90 2005
      12-23-2020, 08:36 AM   #22
Asildur
Drives: 320d 163ps 2005 m47tu2
Hi everyone!
I really need help about this subject.
I have 320d 163ps 2005 model
I tried everything but I couldnt do the set speed display for the cruise control to come up in the dashborad for 3 second when change speed
I dont know maybe its not possible with my car because of kombi module?
I changed codes:
wert_01 to wert_02
ACC_AUSSTATTUNG
wert_04 to wert_01
ACC_ALIVE_ZAEHLER
nicht_aktiv to aktiv
ACC_ID_MONITOR
but its still not showing on dashboard
