Problem With Leather Seat! Need Help!
03-21-2011, 05:49 PM | #1 |
Rep 63
I first owner of my bmw, used to put his baby seat in the back, and since it a coupe, he grinded the carseat against the driver seat and damaged the leather.
It is not too noticeable in person, but annoys me I know I can never restore anymore Is there anything I should do to it? to prevent it from tearing, getting worse? IS BMW OEM leather conditioner the best for this leather? any advice at all??? pictures are below |
03-22-2011, 07:18 AM | #4 |
415
Rep 5,767
You are going to need this...
http://www.detailersdomain.com/leath...ratchaway.aspx Or you can contact Swissvax USA for a Leather Healer for your Leather. |
03-23-2011, 06:24 AM | #5 | |
11
Rep 770
For Leather Type: A-Aniline/Non-Coated Only |
04-18-2011, 08:53 PM | #8 |
Rep 50
Used scratch away on my seats, pretty impressive results.. took 5mins..
Before After (taken immediately after applying, still have to put on conditioner once it has dried) |
04-19-2011, 11:12 AM | #9 |
56
Rep 1,232
04-21-2011, 05:00 PM | #10 |
68
Rep 680
ScheerSpeed helped me fix some scratches on my seat with scratchaway. It worked but the scuffed(hairy) part scuffed more and i put on leathermasters vital and it helped.
04-22-2011, 06:55 AM | #11 |
11
Rep 770
10. Scratched or Scuffed finished leather – If the pigment coating is scratched it needs to be repaired and no amount of cleaning and 'conditioning' will make it go away.
The surfaces need to be correctly prepped and then a pigment (colour) added. By using this kit from Leather Magic; wipe the leather down with the solution, using the 220 grit sand paper; this will remove most of the minor creases. Apply 3-4 thin coats of pigment (allow to dry between coats) you have the option to spray the final coat with a sprayer (all included in kit) – Leather Magic Repair Leather Master Scratch Away (A-Aniline / Non-Coated) is a professional formula designed for uncoated leather to erase these light surface scratches and scuffs. It performs this by moving the surrounding dye to cover the area where the colour is missing. It is perfect for dealing with fingernail type marks. |
