Follow Up for Alarm Coding
03-21-2011, 01:27 AM | #1 |
15
Rep 324
For those having problems with coding the alarm, I have put together the list of values that need to be changed(thanks forum coders). Feel free to correct me if I am wrong.
***Change these values at your own risk. I am not responsible if you mess your car up.*** -The alarm must be installed for this to work -Here is a DIY (from CC 330i) if you have not installed it yet http://www.e90post.com/forums/showthread.php?t=1487 -Add the value for the VO(vehicle options) "+K302" -adding this option would give you access to the DWAI and DWAS modules (and set alarm to default BMW values) - (this step may not be necessary) change the values listed below -DWAI module: LAUTSTAERKE nicht_aktiv > aktiv ALARM_OPT_FERNLICHT nicht_aktiv > aktiv QUIT_AKUST_SCHAERF_KLAPPE nicht_aktiv > aktiv PANIK_ALARM nicht_aktiv > aktiv QUIT_AKUST_ENTSCH nicht_aktiv > aktiv DEF_QUIT_AKUST_ENTSCH nicht_aktiv > aktiv DEF_QUIT_OPT_ENTSCH nicht_aktiv > aktiv DEF_QUIT_AKUST_SCHAERF_KL nicht_aktiv > aktiv ANFRAGE_FENSTERPOSITIONEN nicht_aktiv > aktiv PIAU_AKUST_ENTSCH nicht_aktiv > aktiv PIAU_AKUST_SCHAERF_KLAPPE nicht_aktiv > aktiv SIGNAL_HK nicht_aktiv > aktiv -DWAS module: (change if chirp is too quiet) BUZZER_HIGH_LEVEL wert_06 > wert_04 wert_07 > wert_05 wert_08 -CAS: (panic alarm) SONDERTASTE_PANIKALARM nicht_aktiv > panikalarm MOTORHAUBENKONTAKT (hood switch), thanks onebadmofo nicht_aktiv > aktiv -CAPPL: (change if equipped with idrive) It gives you the option to enable or disable the chirp ACOUSTIC: fkt_gesperrt > fkt_frei C941C_QUITT_AKUST_KLAPPE fkt_gesperrt > fkt_frei K9416_QUITT_AKUST_ENTSCH fkt_gesperrt > fkt_frei C9413_QUITT_AKUST_SCHAERF fkt_gesperrt > fkt_frei Have fun guys! Last edited by E90aL; 04-24-2011 at 09:32 PM.. |
03-21-2011, 08:41 AM | #2 |
Blacked out
Rep 232
This looks dead on. I was going to put together a DIY for the coding part of the install.
E90 330xi Sedan *SOLD*
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq 1997 Eclipse GSX - Project Car - 601hp/475tq |
03-26-2011, 07:34 PM | #4 |
No 55mph
1616
Rep 8,474
Interesting thing on my 09' E92 regarding the Alarm Chirp Volume:
I was going to code the volume higher, but decided to wait since I was getting an entire re-flash at the dealer with the latest & greatest software this week. During my coding session, when I read my DWAS module, these are the settings from factory with the new re-flash: BUZZER_LOW_LEVEL wert_08 BUZZER_HIGH_LEVEL wert_08 I set the high level to wert_04 just to check, & the chirp actually got quieter. Apparently BMW reacted to complaints and set both volumes to wert_08 during one of their software upgrades...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
04-18-2011, 11:07 PM | #5 |
Rep 45
hey, thanks all. I haven't bought it yet, but look forward to it. first need to get the OBD2 cable to tweak other stuff for now.. (also, thanks to OP coder xxxjecxxx)
04-19-2011, 02:49 AM | #6 |
I love the ///M3, but I want 550hp ///M5
141
Rep 3,276
Drives: BMW330iE90
So would you still need to take your car to the dealer after the DIY Install of the OEM Alarm and this coding?
04-19-2011, 08:11 PM | #7 |
Rep 45
No, at least that is my understanding. After reading the DIY alarm install, i figured there must be some software/coding to get the chirp/beep. Researched this forum and was glad to find the coding thread. You should check it out..
04-19-2011, 09:57 PM | #8 |
420
Rep 8,004
Drives: '08 E90 335i, '99 E36 M3
You don't have to code all those values.
Just code $302 to VO and then code the entire car to defaults. It will automatically set the correct values for the new VO. |
StradaRedlands4778.50 |
04-20-2011, 09:35 PM | #10 |
Rep 63
04-20-2011, 10:49 PM | #11 |
420
Rep 8,004
04-23-2011, 07:55 AM | #12 |
Rep 37
Drives: E92
Hello,
I think about of installing the alarm system into my BMW. But i am not sure because of the loudness. In Germany the alarm is very quiet but i do not know to which value BUZZER_HIGH_LEVEL is set in default. But i think it is not on wert_08. Could anyone report me about the loudness with wert_08 and if it makes sense to install the alarm on my car regarding of the loundness? I do not want to have a quite alarm system. Thanks Last edited by 6cylinder; 04-23-2011 at 08:02 AM.. |
04-23-2011, 06:38 PM | #13 |
Rep 63
04-23-2011, 11:13 PM | #14 |
420
Rep 8,004
04-24-2011, 12:21 AM | #15 | |
43
Rep 437
Drives: 2011 E92 335i AW
BTW, on my CAPPL module, the value for ACOUSTIC was nicht_aktiv. I changed it with aktiv. I didn't have fkt_gesperrt for this particular entry. @OP did you figure out how to enable the hood switch? I've programmed everything but the hood switch still doesn't work. Does yours work? Last edited by anthoj; 04-24-2011 at 12:36 AM.. |
04-24-2011, 12:25 AM | #16 |
345
Rep 2,396
Regarding the hood switch
I think either in CAS or FRM module search for "Motorhaube" and set to aktiv You know how I found it? I translated "bonnet" to German in google translate All those years of watching Top Gear finally paid off. I couldn't find anything when I translated "hood" Also for testing purposes you can pull the switch, that's the same as pressing it down and holding. |
04-24-2011, 12:49 AM | #17 | |
15
Rep 324
04-24-2011, 12:01 PM | #18 | |
Rep 63
sys-008 job not found The clock reset on the car, but the date is the same. What's going on? Do I need to add +K302 to the FRM module as well? The fsw_psw.man file is still blank. Last edited by Black Bimmer; 04-24-2011 at 12:07 PM.. |
04-29-2011, 10:36 PM | #20 |
Rep 63
Well that was fun, finally got the alarm coded and fully functional. I changed the FA on the CAS and NFRM modules, then tried to process car > code car but kept getting an error. Finally just coded the individual CAS, DWAI, and DWAS modules using the blank .man file trick and it worked! Lock/unlock chirp, hood switch, panic alarm, tilt switch all functional.
05-09-2011, 06:25 PM | #22 | |
SYTFU Crew
36
Rep 1,179
Drives: 2010 Toyota FJ
for the chirp volume search BUZZER_HIGH_LEVEL in DWAS, change the wert value
