Downpipe questions???
03-14-2011, 08:35 PM | #1 |
93
Rep 651
So I have done a lot of reading on downpipes and have seen dyno results on some DPs that can give you 15-20 HP gains and up to 30 lbs of extra torque but now my concern is the noise.
My intentions were to get DPs and get catback exhaust later on but now I'm hesitant to get DPs and exhaust together cause if the potential loudness. Is this a problem for any of you guys who have this setup? I know for some loud means "better" but like anything there is "better" and there is "annoying". I live in a relatively quiet neighborhood. And my garage faces my next door neighbors bedroom. I would hate to start up my car at midnight to go get a snack or something |
03-15-2011, 12:04 AM | #4 | |
117
Rep 1,625
I am leaving in my midpipes because all of the cars I have heard with no cats in it have a certain "tinnyness" sound in the exhaust note. Some folks have got around this by custom resonators and whatnot, but in general its present.
2014 Individual /// M5 Competition AW/AB || Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge || |
03-15-2011, 12:28 AM | #5 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
DPs do sound nice, but not really loud or an annoying drone. It sounds a bit like an E46 M3 actually.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
03-15-2011, 01:10 AM | #6 | |
Rep 461
Buddy of mine failed with kittyless DP's |
03-15-2011, 08:59 AM | #8 | |
Rep 156
Some tunes will delete the codes while you are running, but I've read that they don't allow the OBD port to be in a "ready mode." The port has to be in that "ready mode" to pass emissions. Please correct me if I am wrong, but this is what I have read about so far. |
03-15-2011, 09:27 AM | #9 | |
117
Rep 1,625
03-15-2011, 09:52 AM | #10 | ||
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
03-15-2011, 10:10 AM | #11 |
Mad Linux Guru On The Loose
1122
Rep 5,399
Drives: 2008 335i Sedan, 2023 M3
One other thing to add:
Check carefully your state emissions laws and regulations. Here in IL, your car is not due for emissions testing until it is 4 years old, which makes sense as most new car warranties last 4 years. So if the exhaust is system is broken, you get it fixed for free at the dealership. So, if you do the math, my car which is a 2008 model, won't be due for emissions testing till the summer of 2012. Also, once the car passes emissions in IL, it won't be due for another 2 years. Finally, check and see if your state has scan-only emissions stations. IL does have those. So for as long as your ECU tells them that everything is kosher, there is nothing to worry about. I run hardware based O2 simulators and everything is fine. I see tons of heavily modded Subarus and Mitsubishi's passing inspections with full catless exhausts here all the time.
03-15-2011, 10:23 AM | #12 | ||
82
Rep 1,615
Drives: '11 E92 335i
If it's an n55, and you run a quality race exhaust with cat-less DP's... it will be loud. If you are in a conservative neighborhood, or are concerned (before even installing anything) then this may not be for you. The n54 definitely has a different exhaust note than the 55 and is 'slightly' softer and less harsh. CRAPPY videos below... but it gets the job done. I have some input from others who were there that day below the vids...
Video 1 - iPhone 4 Video - sound is 'ok' but much more exotic in person: Video 2 - Flip video - sound seems a little better - Cold Start - Mar 13: good luck in your decision........ it's NOT for everyone. Quote:
-madmanhiker jax,fl
