The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Auto-Up Window continues when Door Opened
      03-13-2011, 07:53 AM   #1
Toad335
32
Drives: LCI 335i
Originally Posted by el-drifot
Heres a way to let the windows go automaticly up, when the door is opened (Normally you have to hold the button all the time up, till the window is closed when door is open).
Module: NFRM
TUERAUF_STOP_MAUT -> nicht_aktiv
Code is FH_TUERAUF_STOP_MAUT_3R for 2011. Thanks luigi42.
      03-13-2011, 05:16 PM   #2
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Toad, thanks for posting the popular features individually. It's easier to follow this way.
I've not tried this one yet but according to el-drifot, this is a feature to allow windows to be rolled up (one touch) even if you open your door during the middle of the process. It will not interrupt the windows rolling up.
http://www.e90post.com/forums/showpo...postcount=1610
      03-15-2011, 03:38 PM   #3
Patsfan123
Patsfan123's Avatar
14
Drives: 2007 328xi Coupe
Does this still prevent the window from crushing your arm when the door is closed? IE the safety feature? I saw in the other thread where this was advertised as the safety feature removal.
2007 328xi Coupe | TiAg | Steptronic | Premium | Sport | Nav | Comfort | Cold Weather | BMW Sport Exhaust | BMS PBX | Euro Airbox w/ K&N | Eibach/Bilstein | RDash LED License Plate
      03-15-2011, 03:48 PM   #4
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
That is the pinch protection feature which I believe does not get deactivated when doing this.
      03-15-2011, 06:59 PM   #5
BrynDN
Drives: 335i
Correct. I've tested and the window will still reverse if it encounters an obstruction.
      03-15-2011, 07:02 PM   #6
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
It does takes a considerable amount of force before the protection kicks is so sedan folks need to be careful with this. We, coupes, don't have a door frame
      03-15-2011, 10:34 PM   #7
DESI4life10
201
Yep I tested it and it worked.
Used a towel to double check instead of my finger (just in case).
Window stopped and rolled back all the way down.
      03-19-2011, 09:46 PM   #8
KMAN1981
Drives: 2011 328ci
Module: NFRM
How can a "lay" person program this feature without having to take it to a shop? detailed steps would be greatly appreciated!
      03-19-2011, 10:10 PM   #9
DESI4life10
201
Serious???? You can it or better yet, click the BMW coding Success thread and read the 1st post.
      03-19-2011, 11:08 PM   #10
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Maybe the BMW coding Success thread should be a sticky?
      03-20-2011, 07:58 AM   #11
KMAN1981
Drives: 2011 328ci
Just looked there and dont see any instructions, maybe someone can post a link or you guys can continue to act better then and live immature comments. Thanks
      03-20-2011, 08:17 AM   #12
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
I hope no one helps you.
      03-20-2011, 08:51 AM   #13
DESI4life10
201
      03-26-2011, 07:57 PM   #14
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
Go here:
http://www.e90post.com/forums/showthread.php?t=451145
All the info including what cable to buy, DIY, software downloads, are in the 1st friggen post...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      10-05-2012, 01:02 PM   #15
alexwhittemore
111
Drives: 2009 Crimson 328i
So I just tried this on my 2009 E90 - setting
successfully defeated the interruption ONLY in the case that my key fob is IN. So where previously any opening of any door would stop any window in the process of automatically rolling up, NOW I can open the door with a window in motion and it won't be stopped. BUT if I take the key out, the safety feature behaves as before. Which, of course, sort of defeats the purpose - I want to be able to auto-roll-up as I'm getting out of the car. How often do you open your door while closing your window with the key still in?
At any rate, I haven't searched yet, if I find the other codes to hit I'll post back here for info. In the mean time, if anyone knows off hand, I'd be much obliged
EDIT: So looking around, I don't see anything obvious. But now I've thought of something. It seems to me that the car automatically disables everything once the key is out and a door has been opened. For example, sitting in the car with the key in, I can use all windows. Pull the key out, I can still. But then with the key out, if I open a door, everything locks down until I reintroduce the key. In that case, it kind of makes sense that the window would stop automatically rolling once the car enters that disabled state. So maybe there's not a way to change it. But I wish there was
By the way, sorry to resurrect a year-old thread. But my desire for info stands :P
